Add a 10/100/1000Mbps Ethernet port to any PC through a PCI Express slot. The ST1000SPEX2 PCIe Gigabit Ethernet Network Card adds a 10/100/1000 Mbps compatible RJ45 Ethernet port to a PCI Express-enabled client, server or workstation, providing a convenient addition or replacement networking interface.
Compliant with IEEE 802.3/u/ab standards, and with support for 9K Jumbo Frames, VLAN tagging and Wake on LAN (WOL), this versatile Gigabit NIC/Server Adapter delivers rock-solid performance.
Plus, the card includes both full profile and low profile/half-height installation brackets for installation in a wide range of computer/server chassis, regardless of form factor.
Product Description | StarTech.com 1 Port PCIe Gigabit Network Server Adapter NIC Card - Dual Profile - Gigabit Desktop Adapter REV E Intel 6 Chip support (ST1000SPEX2) - network adapter - PCIe - Gigabit Ethernet | Device Type | Network adapter | Form Factor | Plug-in card - low profile | Interface (Bus) Type | PCI Express x1 | Ports | Gigabit Ethernet | Dimensions (WxDxH) | 2 cm x 12 cm x 8 cm | Weight | 36 g | Data Link Protocol | 10Mb LAN, 100Mb LAN, 1GbE | Data Transfer Rate | 1 Gbps | Processor | 1 x Realtek Semiconductor RTL8111E | Compliant Standards | IEEE 802.3, IEEE 802.3u, IEEE 802.3ab | System Requirements | Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Apple MacOS X 10.6 - 10.9, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019 | Manufacturer Warranty | 2-year warranty | Designed For | P/N: ET91000SM10, ET91000SM20 |
General | |
Networking | |
Connectivity Technology | Wired |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Status Indicators | Link/activity |
Features | Full duplex capability, VLAN support, WOL, auto-uplink (auto MDI/MDI-X), Jumbo Frames support |
Processor / Memory | |
Expansion / Connectivity | |
Interfaces | 1 x 1000Base-T - RJ-45 |
Compatible Slots | 1 x PCI Express x1 |
Miscellaneous | |
Included Accessories | Low-profile bracket |
Compliant Standards | FCC, RoHS |
Software / System Requirements | |
OS Required | Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Apple MacOS X 10.6 - 10.9, Microsoft Windows Server 2016, Microsoft Windows 2000/XP/Vista/7/8/8.1/10, Linux 2.4.x to 4.11.x LTS versions only, Microsoft Windows Server 2019 |
Dimensions & Weight | |
Width | 2 cm |
Depth | 12 cm |
Height | 8 cm |
Weight | 36 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Humidity Range Operating | 10 - 90% |
Compatibility Information | |
