StarTech.com 1-Port GbE SFP Network Card
£124.24
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • INTEL I210 SERIES NETWORK CARD: High-performance 1-port PCIe network card featuring Intel I210-IS chipset adds a gigabit open SFP slot to a desktop or server; Supports IPv4, IPv6, TCP/UDP offloading, link aggregation
  • UNLOCKED 1GB SFP SLOT: Works with any Singlemode/Multimode MSA-compliant or branded SFP/direct attach copper cable (DACC) module; 1Gbps (full-duplex) bandwidth; Fiber enables longer cable runs than copper cabling while being immune to EMI
  • COMPATIBILITY: Works with Windows Server 2012 & up, Windows 10 & up, Linux, VMware ESXi 7.x, and Microsoft Hyper-V; PCI Express Ethernet NIC is compatible with PCIe version 2.1 and works in PCI Express x1 or larger expansion slots
  • THOUGHTFUL DESIGN: LED indicators for port status or network activity monitoring, and to assist with troubleshooting; Full-profile bracket installed by default with a Low-Profile bracket included
  • IT MANAGEABILITY: PXE boot enabled for centralized OS deployment and updates; 9K jumbo frame support for reduced packet overhead; VLAN tagging support for efficient network management; Supports Intel Virtualization Technology (VT-c, VMDq, SR-IOV)
  • Wired / Wireless: Wired
  • Protocol: Gigabit Ethernet, Wired Ethernet
  • Form Factor: Plug-in card
  • Compatibility: [N/A]
  • Type: Network adapter, Adapters
Product codes
chevron icon
chevron icon
Add a 1GbE SFP module to a PCI Express (PCIe) 2.1 x1 (or higher) slot in an IT Administrator workstation or server backplane, using this 1-Port SFP Network Controller.
chevron icon
Product Description StarTech.com 1-Port GbE SFP Network Card, PCIe 2.1 x1, Intel I210-IS, 1GbE Controller, 1000BASE Copper/Fiber Optic, Single-Port Gigabit Ethernet NIC, Desktop/Server Backplanes - Windows and Linux Compatible (P011GI-NETWORK-CARD) - network adapter - PCIe 2.0 - Gigabit SFP x 1
Device Type Network adapter
Form Factor Plug-in card
Interface (Bus) Type PCI Express 2.0 x1
PCI Specification Revision PCIe 2.0, PCIe 2.1
Ports Gigabit SFP x 1
Dimensions (WxDxH) 1.6 cm x 8.7 cm x 6.7 cm
Weight 40 g
Cabling Type Ethernet 1000Base-LX, Ethernet 1000Base-SX, Ethernet 1000Base-T, Ethernet 1000Base-KX
Data Link Protocol 1GbE
Data Transfer Rate 1 Gbps
Capacity Jumbo frame size: 9000
Network / Transport Protocol TCP/IP, UDP/IP, IPv4, IPv6
Processor Intel I210-IS
Compliant Standards IEEE 802.3z, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3ap, IEEE 802.3az, IEEE 802.11ax
Colour Black
System Requirements Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2016, Microsoft Windows Hyper-V Server, Microsoft Windows Server 2019, Microsoft Windows Server 2022, Microsoft Windows 10 / 11, VMware ESXi 7.x, Linux 2.4.x or later (LTS versions only)
chevron icon
Accessories
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£124.24
