This ExpressCard Parallel Adapter turns an ExpressCard slot into a Parallel port, allowing you to connect parallel devices to a laptop computer. The card is PCI Express (x1) based, ensuring faster data transfer rates between host and peripheral than USB-based ExpressCards - providing a cost-effective way to bridge the compatibility gap between your laptop and legacy devices.
A convenient solution for adding a parallel printer or scanner, simply insert the adapter (EC1PECPS) into an available 34mm or 54mm ExpressCard slot and connect the parallel device to the adapter SPP/EPP/ECP parallel port. The adapter card is WHQL certified, so software installation is automated.
Product Description | StarTech.com 1 Port ExpressCard Laptop Parallel Adapter Card - SPP/EPP/ECP - ExpressCard 54 Serial Card - Parallel ExpressCard (EC1PECPS) - parallel adapter - ExpressCard - IEEE 1284 | Device Type | Parallel adapter | Form Factor | Plug-in module | Interface (Bus) Type | ExpressCard/34 | Ports | IEEE 1284 | Dimensions (WxDxH) | 4.4 cm x 11.5 cm x 2 cm | Weight | 40 g | Data Link Protocol | Parallel | Data Transfer Rate | 1.5 Mbps | System Requirements | Microsoft DOS, Linux, Microsoft Windows Server 2003, Microsoft Windows Vista / 2000 / XP | Manufacturer Warranty | 2-year warranty | Designed For | P/N: ECBRACKET2 |
General | |
Networking | |
Ports | IEEE 1284 |
Connectivity Technology | Wired |
Expansion / Connectivity | |
Interfaces | 1 x IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25) |
Compatible Slots | 1 x ExpressCard/34 |
Miscellaneous | |
Compliant Standards | WHQL, FCC, RoHS |
Software / System Requirements | |
Software Included | Drivers & Utilities |
OS Required | Microsoft DOS, Linux, Microsoft Windows Server 2003, Microsoft Windows Vista / 2000 / XP |
Dimensions & Weight | |
Width | 4.4 cm |
Depth | 11.5 cm |
Height | 2 cm |
Weight | 40 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Compatibility Information | |
