StarTech.com 1-Port 2.5G PCIe Network Card
£49.21
22 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • 1-PORT 2.5G ETHERNET CARD: High-performance PCIe 2.5Gbps network card with Intel I225-V chip; Multi-gigabit; Leverage existing Cat5e/Cat6 (or better) cabling; NBASE-T compatible (802.3bz); PCI Express 2.0 x1
  • IT MANAGEMENT: Intel vPro for remote management and troubleshooting; PXE boot enabled for centralized OS deployment and updates; 9K jumbo frame for reduced packet overhead; Remote system boot via WoL; VLAN support for efficient network management
  • BUILD QUALITY: LAN card features built-in heat sink to keep the controller chip cool for optimal performance, LED indicators for link status/speed, and LAN transformers to maintain signal quality and reduce EMI for reliable communications
  • COMPATIBILITY: 2.5GBASE-T variable speed options (2.5G/1G/100M/10M) with auto-negotiation; Multi-Gigabit PC network interface card is compatible with Windows, Windows Server, VMware, and Linux; Low-profile bracket included for hardware compatibility
  • THE IT PRO'S CHOICE: Designed and built for IT Professionals, this 2.5Gbps Network Card is backed for two years, including free lifetime 24/5 multi-lingual technical assistance
  • Wired / Wireless: Wired
  • Protocol: Fast Ethernet, Ethernet, Gigabit Ethernet, 2.5 Gigabit Ethernet + 1 more
  • Form Factor: [N/A]
  • Compatibility: [N/A]
  • Type: Network adapter, Adapters
Product codes
chevron icon
chevron icon
This 2.5 GbE network interface card (NIC) features an Intel I225-V chipset with Intel vPro technology, to enhance performance and data integrity. Variable multispeed options (2.5/1Gbps and 100/10Mbps) enable support for both new and legacy network hardware. Leverage existing Cat5e or CAT6 cabling infrastructure while adding NBASE-T (802.3bz) compatibility for seamless integration.
chevron icon
Product Description StarTech.com 1-Port 2.5G NBASE-T PCIe Network Card, Computer Network Interface Card, Intel I225-V, Single-Port Ethernet, Multi-Gigabit NIC (PR12GI-NETWORK-CARD) - network adapter - PCIe 2.0 - 10/100/1000/2500Base-T x 1
Device Type Network adapter
Form Factor Plug-in card - low profile
Interface (Bus) Type PCI Express 2.0 x1
PCI Specification Revision PCIe 2.0
Ports 10/100/1000/2500Base-T x 1
Dimensions (WxDxH) 1.5 cm x 12.1 cm x 8.9 cm
Weight 100 g
Cabling Type Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 2.5GBase-T
Data Link Protocol 10Mb LAN, 100Mb LAN, 1GbE, 2.5GbE
Data Transfer Rate 2.5 Gbps
Capacity Jumbo frame size: 9000
Processor Intel I225-V
Compliant Standards IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.1x, IEEE 802.1as, IEEE 1588-2008, IEEE 802.3bz, IEEE P802.3az
Colour Black
System Requirements Microsoft Windows Server 2019, VMware ESXi 7.0, Microsoft Windows Server 2022, Microsoft Windows 10 / 11, Linux 5.8.x or later (LTS versions only)
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£49.21
