This Computer Power Cord Extension Cable lets you connect your PC to your monitor, while reducing cable clutter. Expertly designed and constructed of high quality materials, the Power Extension cable features one computer power female connector and one hooded male power connector.
Product Description | StarTech.com 1ft (0.3m) Power Extension Cord, C14 to C13, 10A 125V, 18AWG, Black Computer Power Cord Extension, Power Supply Extension Cable, IEC-320-C14 to IEC-320-C13 AC Power Cable - UL Listed - power extension cable - IEC 60320 C14 to IEC 60320 C13 - 30 cm | Type | Power extension cable | Length | 30 cm | Connector | Power IEC 60320 C14 | Connector (Second End) | Power IEC 60320 C13 | Colour | Black | Manufacturer Warranty | Limited lifetime warranty |
General | |
American Wire Gauge (AWG) | 18 |
Length | 30 cm |
Colour | Black |
Connectivity | |
Miscellaneous | |
Compliant Standards | UL, RoHS |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
