Sony WH-1000XM5 Wireless Noise Cancelling Headphones
free standard delivery
WH-1000XM5
£299.00
Delivery:
Standard: 1-3 working days
Express: Delivered on Wednesday
Express Delivery:
  • 00
    h
  • 00
    m
  • 00
    s
Key features
  • Industry-leading noise cancellation
  • Multi Noise Sensor technology
  • Incomparable noise processing
  • Newly designed driver
  • Magnificent sound, engineered to perfection
  • High-resolution audio with and without wires
  • Accessory Type: Headphones, Headphones / Earphones
  • Connectivity: Wired, Wireless
  • Colour: Black
Product codes
chevron icon
chevron icon
Our best ever noise cancelling headphones, designed for authentic perfection
With two processors controlling eight microphones, Auto NC Optimizer for automatically optimising noise cancelling based on your wearing conditions and environment, and a specially designed driver unit, WH-1000XM5 headphones with industry-leading noise cancelling rewrite the rules for distraction-free listening and call clarity.
From airplane noise to people’s voices, our WH-1000XM5 wireless headphones with multiple microphone noise cancelling keep out more high and mid frequency sounds than ever. And with Auto NC Optimizer, noise cancelling is automatically optimised based on your wearing conditions and environment.
With four microphones on each earcup, this is our biggest ever step forward in noise cancelling. Ambient sound is captured even more accurately for a dramatic reduction in high frequency noise. Thanks to Auto NC Optimizer, noise cancelling performance is always and automatically optimised based on wearing conditions and external environmental factors such as atmospheric pressure.
Incomparable noise cancelling
Specially developed by Sony, the Integrated Processor V1 unlocks the full potential of our HD Noise Cancelling Processor QN1. This unique combination of technology controls eight microphones to deliver unprecedented noise cancelling quality.
Specially designed 30mm driver unit
The specially designed 30mm driver unit featuring a soft edge enhances noise cancelling helping you enjoy your music precisely without ambient noise. The carbon fiber composite material realizes light weight and high rigidity dome and improves sound clarity, especially in high frequency ranges.
Enjoy High-Resolution Audio with and without wires
The WH-1000XM5 supports High-Resolution Audio and High-Resolution Audio Wireless, thanks to LDAC, our industry-adopted audio coding technology. LDAC transmits approximately three times more data than conventional Bluetooth® audio for exceptional High-Resolution Audio quality.
Real-time restoration of all your compressed files
Using Edge-AI (Artificial Intelligence), DSEE Extreme™ upscales compressed digital music files in real time. Dynamically recognising instrumentation, musical genres and individual elements of each song, it restores high range sound lost in compression.
Industry-leading call quality
Our Precise Voice Pickup Technology uses four beamforming microphones and an AI-based noise reduction algorithm to isolate your voice precisely. A newly developed wind noise reduction structure minimises wind noise during calls. Wherever you are, you’ll always hear and be heard clearly.
Multiple microphones, focused on your voice
Equipped with four beamforming microphones, these headphones are calibrated to only pick up your voice. An improved signal-to-noise ratio enables them to catch every single word, even when there’s a lot of noise around.
Ultra clear, noise-free calls
With Precise Voice Pickup Technology and advanced audio signal processing, the person on the other end of the call will hear your voice clearly, even when you are in noisy situations. Our noise reduction algorithm was developed with AI machine learning using more than 500 million voice samples to suppress ambient noise and extract your voice clearly in a wide range of environments.
All day comfort with a noiseless design
These lightweight headphones are beautifully finished in newly developed "Soft fit leather". This material fits snugly around the head with less pressure on the ears while keeping out external sounds. Our noiseless design with stepless slider, seamless swivel and hanger makes WH-1000XM5 a pleasure to wear.
chevron icon
Product Description Sony WH-1000XM5 - headphones with mic
Product Type Headphones - Bluetooth - wireless, wired - 3.5 mm jack
Recommended Use Portable electronics
Colour Black
Headphones Form Factor Full size
Connectivity Technology Wireless, wired
Wireless Technology Bluetooth
Headphones Technology Dynamic
Bluetooth Version Bluetooth 5.2
Sound Effects Digital Sound Enhancement Engine Extreme (DSEE Extreme), Ambient Sound Mode, 360 Reality Audio
Audio Specifications Frequency Response 4 - 40000 Hz
Active Noise Canceling Yes
Microphones Included 8
Intelligent Assistant Google Assistant, Alexa
chevron icon
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been opened but is in excellent condition
Ref: GW36 048643
£263.34
product
Ref: GW36 048643
Accessories
Packaging
Functional
Software
Manuals
£263.34
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
chevron icon
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
£299.00
