VAIO E series offers up ample space for web surfing and gaming. The way you enjoy VAIO E series is up to you, but no matter which room you take it to, you can always count on a beautiful view. VAIO E series features a transparent design finish that gives a sense of depth, and gradient color patterns that add richness to the simple shape of the unit.
Product Description | Sony VAIO E Series SVE1512K1E - 15.5" - Intel Core i5 3210M - 4 GB RAM - 640 GB HDD | Product Type | Notebook | Operating System | Win 8 | Processor | Intel Core i5 (3rd Gen) 3210M / 2.5 GHz (3.1 GHz) / 3 MB Cache | Memory | 4 GB DDR3 (1 x 4 GB) | Storage | 640 GB HDD / 5400 rpm | Optical Drive | DVD SuperMulti | Display | 15.5" LED backlight 1366 x 768 / WXGA | Graphics | Intel HD Graphics 4000 | Keyboard Backlight | Yes | Numeric Keypad | Yes | Integrated Webcam | Yes | Networking | 802.11b/g/n, Bluetooth 4.0, Gigabit Ethernet | Colour | Black | Dimensions (WxDxH) | 37.19 cm x 25.35 cm x 3.51 cm | Weight | 2.7 kg | Microsoft Office Preloaded | Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC. | Environmental Standards | ENERGY STAR Qualified EPEAT Silver | Manufacturer Warranty | Limited warranty - 1 year |
General | |
Operating System | Windows 8 |
Processor / Chipset | |
CPU | Intel Core i5 (3rd Gen) 3210M / 2.5 GHz |
Max Turbo Speed | 3.1 GHz |
Number of Cores | Dual-Core |
Cache | L3 - 3 MB |
64-bit Computing | Yes |
Chipset | Mobile Intel HM76 Express |
Features | Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 4 GB (1 x 4 GB) |
Max RAM Supported | 8 GB |
Technology | DDR3 SDRAM |
Speed | 1600 MHz / PC3-12800 |
Rated Speed | 1600 MHz |
Storage | |
Main Storage | 640 GB HDD SATA 3Gb/s / 5400 rpm |
Optical Drive | DVD±RW (±R DL) / DVD-RAM fixed |
Read Speed | 24x (CD) / 8x (DVD) |
Write Speed | 24x (CD) / 8x (DVD±R) / 6x (DVD±R DL) |
CD / DVD Rewrite Speed | 10x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM) |
Display | |
Type | 15.5" |
LCD Backlight Technology | LED backlight |
Resolution | 1366 x 768 (WXGA) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Features | Glare |
Audio & Video | |
Graphics Processor | Intel HD Graphics 4000 |
Memory Allocation Technology | Dynamic Video Memory Technology |
Camera | Yes |
Resolution | 1.31 Megapixel |
Video Resolutions | 1280 x 1024 |
Camera Features | Exmor Technology |
Sound | Stereo speakers, microphone |
Audio Features | Output: xLOUD |
Input | |
Type | Keyboard, touchpad |
Features | Touchpad with gesture support |
Communications | |
Wireless | 802.11b/g/n, Bluetooth 4.0 |
Network Interface | Gigabit Ethernet |
Battery | |
Technology | Lithium Ion |
Connections & Expansion | |
Interfaces | 3 x USB 2.0 , USB 3.0 , Headphone output , Microphone input , HDMI , VGA , LAN |
Memory Card Reader | Yes (SD Card, Memory Stick PRO, Memory Stick Duo, SDHC Card, SDXC Card) |
Software | |
Software Included | VAIO Update, McAfee Internet Security Suite (30 days subscription), VAIO Care, VAIO Gate, VAIO Transfer Support, Microsoft Office 2010 Starter, Adobe Reader 10, Sony PlayMemories Home, Microsoft Internet Explorer 10, VAIO Message Center, McAfee Parental Controls |
Miscellaneous | |
Colour | Black |
Features | Security lock slot (cable lock sold separately), charging via USB, anti-shock hard drive |
Dimensions & Weight | |
Weight | 2.7 kg |
Sustainability Information | |
EPEAT Compliant | EPEAT Silver |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
