A soft head pad and ear cushions give you the comfort you need for long listening. No need to get up or move from the sofa, simply adjust audio levels using the volume control on the headphones.
Product Description | Sony MDR-RF855RK - headphones | Product Type | Headphones - wireless | Recommended Use | Home audio | Headphones Form Factor | Full size | Connectivity Technology | Wireless | Headphones Technology | Dynamic | Sound Output Mode | Stereo | Audio Specifications | Frequency Response 10 - 22000 Hz | Controls | Volume |
General | |
Dimensions & Weight Details | Headphones: 285 g , Transmitter: 16.6 cm x 12.6 cm x 9.4 cm / 300 g |
Weight | 285 g |
Max Operating Distance | 100 m |
Audio Output | |
Frequency Response | 10 - 22000 Hz |
Diaphragm | 40 mm |
Magnet Material | Neodymium |
Remote Control | |
Controls | Volume |
Wireless Link | |
Transmission Range | 100 m |
Connections | |
Connector Type | Headphones (mini-phone stereo 3.5 mm) , Audio line-in (RCA x 2) |
Miscellaneous | |
Included Accessories | Transmitter unit |
Cable Details | Headphones cable - 1 m |
Power | |
Power Device | Power adapter - external |
Battery | Battery rechargeable - Nickel Metal Hydride |
Capacity | 550 mAh |
Run Time (Up To) | 18 hour(s) |
Recharge Time | 7 hour(s) |
