The SAL35F18.AE is a bright, wide aperture lens which is ideal for portraits and low-light shooting.
Product Description | Sony SAL35F18 - wide-angle lens - 35 mm | Lens System | Wide-angle lens | Intended For | Digital SLR, full-frame digital SLR | Mounting Type | Sony A-type | Lens Aperture | F/1.8 | Focal Length | 35 mm | Min Focus Distance | 23 cm | Focus Adjustment | Automatic, manual | Lens Construction | 5 groups / 6 elements | Special Functions | Wide angle | Filter Size | 55 mm | Length | 5.2 cm | Weight | 170 g | Designed For | ? SLT-A57, SLT-A57K, SLT-A57M, SLT-A57Y, SLT-A58, SLT-A58K, SLT-A58M, SLT-A58Y, SLT-A65, SLT-A65VK, SLT-A65VL, SLT-A65VM, SLT-A65VY |
General | |
Length | 5.2 cm |
Diameter | 7 cm |
Weight | 170 g |
Lens System | |
Type | Wide-angle lens |
Minimum Aperture | F/22 |
Focal Length Equivalent to 35mm Camera | 53mm |
Magnification | 0.25 |
Max View Angle | 44 degree(s) |
Diaphragm Blades | 7 |
Features | Smooth Autofocus Motor (SAM) |
Miscellaneous | |
Included Accessories | Lens hood, dust cap, lens cap |
Compatibility Information | |
Designed For | Sony a SLT-A57, SLT-A57K, SLT-A57M, SLT-A57Y, SLT-A58, SLT-A58K, SLT-A58M, SLT-A58Y, SLT-A65, SLT-A65VK, SLT-A65VL, SLT-A65VM, SLT-A65VY |
