You can't do this with a smartphone. Snap pin-sharp, 18.2 MP photos from afar with the 20x zoom camera that fits in your pocket. There is also ultra-smooth recording that minimizes shake while shooting on the move, perfect for video lovers. Like taking shots in near darkness but hate disturbing the mood with a flash? The Exmor R CMOS image sensor harnesses lots of light to make candlelit moments really shine.
Product Description | Sony Cyber-shot DSC-WX350 - digital camera | Product Type | Digital camera - compact | Memory Card Slot | Memory Stick PRO Duo card, SD card | Image Processor | BIONZ X | Wireless Interface | Wi-Fi, NFC | Sensor Resolution | 18.2 Megapixel | Max Video Resolution | 1920 x 1080 | Lens System | Zoom lens - 20x zoom - 4.3 - 86 mm - f/3.5-6.5 G | Focus Adjustment | Automatic | Min Focus Distance | 5 cm | Image Stabiliser | Optical (Steady Shot with Intelligent Active Mode) | Camera Flash | Built-in flash | Display | LCD display - 3" | Supported Battery | Sony NP-BX1 Li-ion rechargeable battery - 1240 mAh (included) | Interface | HDMI, USB 2.0 | Microsoft Certification | Compatible with Windows 7 | Colour | White | Dimensions (WxDxH) | 9.6 cm x 2.57 cm x 5.49 cm | Weight | 137 g |
General | |
Enclosure Colour | White |
Optical Sensor Type | Exmor R CMOS |
Total Pixels | 21,100,000 pixels |
Effective Sensor Resolution | 18,200,000 pixels |
Optical Sensor Size | 1/2.3" |
ISO (Max) | 12800 |
Optical Zoom | 20x |
Built-in Optical Image Stabiliser | Yes |
Face Detection | Yes |
Print Standard | DPOF support, Exif Print support, PRINT Image Matching |
Auto Focus | TTL contrast detection |
Face Detection | Face-priority AF function, Smile Shutter |
Digital Video Format | AVCHD, H.264 |
Image Recording Format | JPEG |
Interface | HDMI, USB 2.0, IEEE 802.11b/g/n, NFC (Near Field Communication) |
Exposure & White Balance | |
Light Sensitivity | ISO 100, ISO 800, ISO 400, ISO 200, ISO 80, ISO 1600, ISO 6400, ISO 3200, ISO auto (80-1600), ISO 12800 |
Exposure Metering | Multi-segment, centre-weighted, spot |
Exposure Modes | Programme, automatic |
Shooting Programs | Landscape, portrait mode, night portrait, PET, fireworks, night scene, beach, snow, high sensitivity, soft skin, handheld twilight, gourmet, anti-motion blur, backlight correction HDR |
Special Effects | Soft focus, illustration, Water Colour, miniature, Retro, partial colour, Toy camera, Posterisation, High contrast monochrome, Pop Colour, HDR Painting, Rich-tone monochrome, Soft High-key |
White Balance | Custom, automatic, presets |
White Balance Presets | Incandescent, cloudy, Flash, daylight, fluorescent light (cool white), fluorescent light (daylight), fluorescent light (daylight white) |
Max Shutter Speed | 1/1600 sec |
Min Shutter Speed | 4 sec |
Exposure Compensation | ±2 EV range, in 1/3 EV steps |
Lens System | |
Type | Zoom lens - 20x zoom - 4.3 - 86 mm - f/3.5-6.5 G |
Focal Length Equivalent to 35mm Camera | 25 - 500mm |
Macro Focus Range | 5cm |
Zoom Adjustment | Motorised drive |
Lens Construction | 10 groups / 11 elements |
Features | Built-in lens shield, aspherical lens |
Camera Flash | |
Flash Modes | Fill-in mode, slow synchro, auto mode, flash OFF mode, red-eye reduction |
Red-Eye Reduction | Yes |
Features | AF illuminator |
Effective Flash Range | 0.2 m - 4.3 m: ISO auto (wide lens) , 2 m - 2.4 m: ISO auto (tele lens) , 6.1 m: ISO 3200 (wide lens) , 3.4 m: ISO 3200 (tele lens) |
Additional Features | |
Continuous Shooting Speed | 10 frames per second for 10 frames |
Self-Timer Delay | 10 sec, 2sec |
Additional Features | Histogram display, takes photos while film recording, USB charging, built-in help guide, Intelligent AUTO (iAUTO), Superior Auto mode, BRAVIA Sync function, Intelligent Sweep Panorama (360) |
Display | |
Type | 3" LCD display |
Display Format | 460,800 pixels |
Display Form Factor | Built-in |
Display Features | Display brightness control |
Microphone | |
Microphone Operation Mode | Stereo |
Microphone Features | Wind noise reduction |
Connections | |
Connector Type | USB 2.0 , HDMI output |
Miscellaneous | |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Included Accessories | AC power adaptor, wrist strap, micro-USB cable |
Battery | |
Battery Type | Sony NP-BX1 Lithium Ion |
Details | Sony NP-BX1 Li-ion rechargeable battery - 1240 mAh (included) |
Battery Life Details | Photo shooting - 470 shots , Playback - 3.9 hours |
Memory / Storage | |
Supported Memory Cards | Memory Stick Duo, SD Memory Card, Memory Stick PRO Duo, SDXC Memory Card, Memory Stick PRO Duo Mark2, SDHC Memory Card, Memory Stick PRO-HG Duo, Memory Stick XC-HG Duo |
Image Storage | JPEG 4896 x 3672 , JPEG 4896 x 3264 , JPEG 4896 x 2752 , JPEG 3648 x 2736 , JPEG 3648 x 2432 , JPEG 3648 x 2056 , JPEG 2592 x 1944 , JPEG 2592 x 1728 , JPEG 1920 x 1080 , JPEG 640 x 480 , JPEG 3664 x 3664 , JPEG 2736 x 2736 , JPEG 1920 x 1920 |
Video Capture | AVCHD - 1920 x 1080 - 50 fps - 28Mbps , AVCHD - 1920 x 1080 - 50 fps - 24Mbps , AVCHD - 1920 x 1080 - 50 fps - 17Mbps , H.264 - 1440 x 1080 - 25 fps - 12Mbps , H.264 - 640 x 480 - 25 fps - 3Mbps |
Dimensions & Weight | |
Width | 9.6 cm |
Depth | 2.57 cm |
Height | 5.49 cm |
Weight | 137 g |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
