Sony's powerful 4K Processor X1 brings stunning clarity to whatever you're watching - 4K content, high definition, standard definition or even low-resolution Internet videos. The power-packed X1 chip is key to sensational 4K picture by evolving greater clarity, brilliant color and high contrast - with any input and whatever you're watching. Every source is intelligently analyzed to ensure the stunning detail of 4K. Both SD and HD are carefully up-scaled to near 4K quality. Whatever you watch is delivered with subtle colors and refined textures. Picture noise is reduced and contrast is dynamically enhanced for bright, sparkling highlights and rich deep blacks.
The Android TV makes your viewing smarter than ever. Imagine everything you love doing on your tablet or smartphone: now on the big screen. Sony Android TV brings it all to life in your living room, letting you explore a world of movies, music, photos, games, search, Apps and more - all brought to you with fabulous Sony picture and sound quality.
Product Description | Sony Bravia KDL-65W855C W855C Series - 65" LED-backlit LCD TV - Full HD | Product Type | LED-backlit LCD TV - Smart TV | Diagonal Class | 65" | Colour | Black | 3D | Yes | 3D Technology | Active | Platform | Android TV | Resolution | 1920 x 1080 | Display Format | 1080p | Input Video Formats | 1080/24p, 1080/60i, 480/60p, 720/60p, 1080/50i, 576/50p, 1080/50p, 1080/60p, 1080/30p, 480/60i, 576/50i, 720/24p, 720/30p | Frame Rate & Enhancement Technology | Motionflow XR 800 | 24p Technology | 24p True Cinema | Video Interface | Component, composite, HDMI, SCART | HDMI Ports Qty | 4 ports | Connectivity | Wi-Fi, LAN, Bluetooth | PC Interface | Mobile High-Definition Link (MHL) | HDCP Compatible | Yes | LCD Backlight Technology | Direct-lit LED | Image Aspect Ratio | 16:9 | TV Tuner | 1x analogue, 1x digital | Digital TV Tuner | DVB-C, DVB-S, DVB-S2, DVB-T, DVB-T2 | Internet Streaming Services | Google Play | Multi-channel Preview | Picture-and-picture (PAP) | Speaker System | 2 speakers | Sound Effects | S-FORCE Front Surround Sound | Stereo Reception System | NICAM, A2 | USB | 3 ports | Included Accessories | Sony RMT-TX100D remote control, batteries | Energy Class | Class A+ | Power Consumption Operational | 230 Watt | Power Consumption (On mode) | 123 W | Power Consumption Stand by | 0.5 Watt | Energy Consumption per Year | 171 kWh | Dimensions (WxDxH) - without stand | 145.5 cm x 7.8 cm x 84.3 cm | Weight | 23.4 kg |
General | |
Series | W855C Series |
3D | Yes |
TV Tuner Presence | Yes |
Sensors | Light sensor |
Modes | Film Mode, backlight off mode, Live Football Mode |
Timer Functions | Sleep, wake |
Dimensions | Without stand |
Width | 145.5 cm |
Depth | 7.8 cm |
Height | 84.3 cm |
Weight | 23.4 kg |
Enclosure Colour | Black |
Display | |
Widescreen Modes | Zoom 14:9, Auto Wide, Full, Wide Zoom, Zoom, Normal |
Viewing Angle | 178 degrees |
Viewing Angle (Vertical) | 178 degrees |
Features | Advanced Contrast Enhancer circuit (ACE), i-Manual, X-Reality PRO Engine, Tv SideView, CineMotion, Cinema Drive, Dynamic Backlight Control, One-Flick Entertainment |
Stands & Mounts | |
Stand | Included |
Stand Design | Tabletop |
Stand Colour | Silver mirror |
Flat Panel Mount Interface | Yes |
TV Tuner | |
Conditional Access | Common Interface Plus (CI+) slot |
Digital TV Tuner | |
HDTV Tuner | Yes |
Video Features | |
Electronic Programme Guide | Digital EPG |
Parental Channel Lock | Yes |
Media Player | |
USB Port | Yes |
USB Ports Qty | 3 |
Operating System | Android OS 5.0 |
Remote Control | |
Type | Remote control |
Remote Control Model | Sony RMT-TX100D |
Features | Scene Select, One-Flick Remote |
Audio System | |
Digital Audio Format | Dolby Digital output, Dolby Digital Plus output, Dolby Pulse output |
Surround Mode | Yes |
Audio Controls | Sound mode |
Output Power / Total | 20 Watt |
Features | S-Master Digital Amplifier, Clear Phase Speaker, Digital Sound Enhancement Engine (DSEE), Long Duct Speaker, Clear Audio+, Bass Reflex Speaker System, Google Cast support |
Speakers | 2 x main channel speaker - 10 Watt |
Network & Internet Multimedia | |
Functionality | Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback |
LAN Protocol | Ethernet |
Connect & Share | Wi-Fi Direct, Screen Mirroring |
Supported Consumer Electronics Control (CEC) | BRAVIA Sync Function |
Connections | |
Connector Type | 4 x HDMI input , SCART - rear , 3 x USB , LAN - rear , Composite video / component video input , Audio line-in , SPDIF output - rear , Audio line-out / headphones / subwoofer - side |
Miscellaneous | |
Included Accessories | Batteries |
Power | |
Power Device | Power supply |
Dimensions & Weight Details | |
Dimensions & Weight Details | Panel without stand - 145.5 cm x 7.8 cm x 84.3 cm x 23.4 kg , Panel with stand - 145.5 cm x 26.5 cm x 89.1 cm x 24.5 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 155.3 cm |
Depth (Shipping) | 22.4 cm |
Height (Shipping) | 94.3 cm |
