The Seagate Enterprise Performance 10K HDD is an ideal 1.2 TB hard drive for mission critical applications. It delivers best-in-class mission critical random performance, highest capacities and the low power that data centers need to meet demanding service level agreements and to keep up with data growth and reduce IT operating costs.
Product Description | Seagate Enterprise Performance 10K HDD ST1200MM0118 - hard drive - 1.2 TB - SAS 12Gb/s | Type | Hard drive - internal | Capacity | 1.2 TB | NAND Flash Memory Type | Enterprise multi-level cell (eMLC) | Form Factor | 2.5" SFF | Interface | SAS 12Gb/s | Data Transfer Rate | 1.2 GBps | Buffer Size | 128 MB | Spindle Speed | 10000 rpm | Features | PowerChoice, Protection Information (PI), Seagate RAID Rebuild, Seagate TurboBoost, S.M.A.R.T. | Dimensions (WxDxH) | 70.1 mm x 100.45 mm x 15 mm | Weight | 193 g | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 1.2 TB |
Bytes per Sector | 4096 |
Width | 70.1 mm |
Depth | 100.45 mm |
Height | 15 mm |
Weight | 193 g |
Performance | |
Drive Transfer Rate | 1.2 GBps (external) |
Internal Data Rate | 241 MBps |
Average Latency | 2.9 ms |
Reliability | |
MTBF | 2,000,000 hours |
Non-Recoverable Errors | 1 per 10^16 |
Expansion & Connectivity | |
Interfaces | 1 x SAS 12 Gb/s |
Compatible Bay | 2.5" SFF |
Power | |
Power Consumption | 4.26 Watt (idle) , 7.25 Watt (active) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 55 °C |
Shock Tolerance (operating) | 40 g @ 11 ms |
Shock Tolerance (non-operating) | 400 g @ 2 ms |
