Smart. Safe. Secure. Seagate provides drives specifically for surveillance storage for years. SkyHawk is built to keep systems in the field longer and reduce the need for post-deployment support.
Product Description | Seagate SkyHawk Surveillance HDD ST8000VX0022 - hard drive - 8 TB - SATA 6Gb/s | Type | Hard drive - internal | Capacity | 8 TB | Form Factor | 3.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Buffer Size | 256 MB | Spindle Speed | 7200 rpm | Features | RV Sensor, 24x7 availability | Dimensions (WxDxH) | 101.85 mm x 146.99 mm x 26.11 mm | Weight | 780 g | Manufacturer Warranty | 3-year warranty |
General | |
Device Type | Hard drive - internal |
Capacity | 8 TB |
Width | 101.85 mm |
Depth | 146.99 mm |
Height | 26.11 mm |
Weight | 780 g |
Performance | |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 210 MBps |
Reliability | |
MTBF | 1,000,000 hours |
24x7 Operation | Yes |
Non-Recoverable Errors | 1 per 10^15 |
Load / Unload Cycles | 300,000 |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s - 7 pin Serial ATA |
Compatible Bay | 3.5" |
Power | |
Power Consumption | 2 Watt (start) , 9 Watt (active) , 7.6 Watt (idle) , 0.6 Watt (sleep) , 0.6 Watt (standby) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 70 °C |
