With Seagate Wireless Plus, you can enjoy your media and access your files without wires or the Internet. This mobile storage device broadcasts its own Wi-Fi network, so you can wirelessly stream your media and files to your tablet or smartphone on-the-go and off-the-grid.
Forget about having to choose which files to load onto your tablet or smartphone before a trip. Bring it all with you! Simply drag-and-drop to load files wirelessly from your PC or Mac computer or use the USB 3.0 adapter to load files up to 10x faster than Wi-Fi N.
Wireless Plus allows up to eight tablets and smartphones to access and store content at the same time. Leave it in your bag, set it on the table, place it anywhere in the car - with a range of up to 150 feet you'll never feel tethered to your storage. Best of all, by creating its own Wi-Fi network, there is no need for an Internet connection and you don't have to use your data plan.
At home, Wireless Plus can stream media to your TV too. Game consoles, smart TVs, connected Blu-ray players and other DLNA devices can access the content on Wireless Plus whenever you have it connected to your home network via Wi-Fi. If you have an Apple TV, your iPad, iPhone and iPod touch can use Airplay to take your media from small screen to big screen.
Product Description | Seagate Wireless Plus STCK1000200 - NAS server - 1 TB | Device Type | NAS server | Host Connectivity | USB 3.0 / 802.11n | Total Storage Capacity | 1 TB | Dimensions (WxDxH) | 89 mm x 199 mm x 127 mm | Weight | 256 g () | Localisation | EMEA | Storage Controller | USB 3.0 | Hard Drive | 1 x 1 TB | Networking | Radio access point 802.11b/g/n | System Requirements | Apple MacOS X 10.6 or later, Apple iOS 4.3 or later, Android 2.3 or later, Microsoft Windows Vista / XP / 7 / 8 | Microsoft Certification | Compatible with Windows 7 | Manufacturer Warranty | 3-year warranty |
General | |
Width | 89 mm |
Depth | 199 mm |
Height | 127 mm |
Weight | 256 g () |
Enclosure Colour | Grey |
Storage Controller | |
Bus Type | SuperSpeed USB 3.0 |
Hard Drive | |
Type | HDD |
Capacity | 1 x 1 TB |
Networking | |
Type | Radio access point |
Data Link Protocol | 802.11b/g/n |
Compliant Standards | DLNA CERTIFIED |
Expansion / Connectivity | |
Interfaces | 1 x SuperSpeed USB 3.0 |
Miscellaneous | |
Cables Included | 1 x USB 3.0 cable |
Features | AirPlay |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Software / System Requirements | |
OS Required | Apple MacOS X 10.6 or later, Apple iOS 4.3 or later, Android 2.3 or later, Microsoft Windows Vista / XP / 7 / 8 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
