Sapphire HD 7970 Vapor-X Edition has the GDDR5 memory clocked at 6000 MHz effective, and runs with a core clock speed of 1000 MHz which with PowerTune dynamic boost rises to 1050 MHz on the engine. It has a slightly less sophisticated 8-phase power design and the versatile output configuration of Dual-link DVI-I, DVI-D, HDMI and DisplayPort.
The Vapor-X cooler is based on a vapor chamber designed especially for this series. Heat is carried away by four heatpipes, and finally dispersed by two 90 mm fan with aerofoil blades and dust repelling bearings. The Vapor-X cooler easily handles the heat generated from the HD 7970 GHz Editions even under extreme load conditions.
Product Description | Sapphire VAPOR-X HD 7970 - GHz Edition - graphics card - Radeon HD 7970 - 3 GB | Device Type | Graphics card | Bus Type | PCI Express 3.0 x16 | Graphics Engine | AMD Radeon HD 7970 | Memory | 3 GB GDDR5 | Core Clock | 1050 MHz | Stream Processors | 2048 | Effective Memory Clock | 6 GHz | Memory Interface | 384-bit | Max Resolution | 2560 x 1600 | Interfaces | 2 x DVI-I (dual link) , HDMI , DisplayPort , VGA - with adapter | API Supported | DirectX 11, OpenGL 4.2 | Dimensions (WxDxH) | 4.5 cm x 28.5 cm x 13.5 cm | Package Type | Retail |
General | |
Process Technology | 28 nm |
Max Resolution | 2560 x 1600 at 60 Hz |
Features | Vapor-X cooling system, AMD HD3D Technology, AMD PowerPlay technology, AMD CrossFireX Technology, AMD PowerTune technology, AMD Stream technology, AMD App Acceleration, AMD Eyefinity Technology 2.0, AMD HD Media Accelerator, Dual-X cooler, AMD ZeroCore Power technology |
Memory | |
Size | 3 GB |
Technology | GDDR5 SDRAM |
Effective Clock Speed | 6 GHz |
Bus Width | 384-bit |
System Requirements | |
Min RAM Size | 4 GB |
Required Power Supply | 500 W |
Additional Requirements | CD-ROM, two 8-pin power connectors |
Miscellaneous | |
Cables Included | 1 x DVI-VGA adapter , 1 x HDMI cable - 1.8 m , 1 x CrossFire internal bridge |
Software Included | Sapphire TriXX |
Width | 4.5 cm |
Depth | 28.5 cm |
Height | 13.5 cm |
