High Performance and High Reliability Meet High Style
Built with SanDisk’s sixth-generation TLC flash, the X400 SSD offers quick responsiveness, high reliability and low power for a seamless experience for thin and ultramobile notebooks. It’s the ideal storage solution for heavy workloads such as photo and video editing, multitasking or office productivity.
Thin Is In
With a 1.5mm single-sided form factor (M.2 2280 module), the X400 SSD is the first single-sided 1TB SSD in the industry, giving it the performance and capacities ideal for ultrathin designs. The X400 SSD is also available in 2.5" 7mm-height to be a true drop in replacement for mechanical HDDs.
nCache TM 2.0 and DataGuardTM: Advanced Technologies for A Better Experience
SanDisk technologies combine nCache 2.0, DataGuard and LDPC error correction into the X400 SSD for a superior experience and endurance levels up to 320 TBW (terabytes written), our highest ever for a client drive. SanDisk nCache 2.0 is a set of advanced algorithms that analyze workloads to improve fast burst performance and sustained sequential write speeds while minimizing energy consumption and controller overhead. The X400 SSD is backed by a 5-year warranty.
Designed With Security in Mind
The X400 SSD includes self-encrypting drive (SED) capabilities to quickly and easily protect sensitive documents from theft or disclosure. We also support TCG Opal 2.0 for interoperability with a wide spectrum of security software platform.
Product Description | SanDisk X400 - SSD - 256 GB - SATA 6Gb/s | Type | Solid state drive - internal | Capacity | 256 GB | NAND Flash Memory Type | Triple-level cell (TLC) | Form Factor | 2.5" | Interface | SATA 6Gb/s | Data Transfer Rate | 600 MBps | Features | Device Initiated Power Management (DIPM), DEVSLP SATA low power mode, DataGuard Technology, nCache 2.0 technology, LDPC error correction | Dimensions (WxDxH) | 69.85 mm x 100.5 mm x 7 mm | Weight | 37.4 g | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Solid state drive - internal |
Capacity | 256 GB |
Width | 69.85 mm |
Depth | 100.5 mm |
Height | 7 mm |
Weight | 37.4 g |
Performance | |
SSD Endurance | 80 TB |
Drive Transfer Rate | 600 MBps (external) |
Internal Data Rate | 540 MBps (read) / 520 MBps (write) |
4KB Random Read | 93500 IOPS |
4KB Random Write | 60000 IOPS |
Reliability | |
MTBF | 1,750,000 hours |
Expansion & Connectivity | |
Interfaces | 1 x SATA 6 Gb/s - 7 pin Serial ATA |
Compatible Bay | 2.5" |
Power | |
Power Consumption | 70 mW (average) , 2350 mW (read) , 3400 mW (write) |
Miscellaneous | |
Compliant Standards | UL, TUV, VCCI, BSMI, FCC, KC |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Shock Tolerance (operating) | 1500 g @ 0.5 ms half-sine pulse |
Shock Tolerance (non-operating) | 500 g @ 0.5 ms half-sine pulse |
Vibration Tolerance (operating) | 5 g @ 10-2000 Hz |
Vibration Tolerance (non-operating) | 4.9 g @ 7-800 Hz |
