Samsung 49'' MU6500 Curved Active Crystal Colour Ultra HD HDR Smart TV
Product Description | Samsung UE49MU6500U 6 Series - 49" LED-backlit LCD TV - 4K | Product Type | Curved LED-backlit LCD TV - Smart TV | Diagonal Class | 49" | Colour | Silver | Resolution | 3840 x 2160 | Display Format | 4K UHD (2160p) | Frame Rate & Enhancement Technology | 1600 Picture Quality Index | Video Interface | Component, composite, HDMI | HDMI Ports Qty | 3 ports | Connectivity | Wi-Fi, LAN, Bluetooth | LCD Backlight Technology | LED backlight UHD dimming | Image Aspect Ratio | 16:9 | TV Tuner | 1x analogue, 1x digital | Digital TV Tuner | DVB-C, DVB-S2, DVB-T2 | Picture Enhancements | Digital Clean View, Mega Contrast, Ultra Clean View, UHD Upscaling, Accessibility High contrast, Auto Depth Enhancer, Active Crystal Colour | Speaker System | 2 speakers | USB | 2 ports | Included Accessories | Samsung TM1750A remote control, batteries | Voltage | AC 230V (50/60 Hz) | Energy Class | Class A | Power Consumption Operational | 150 Watt | Power Consumption (On mode) | 90 W | Power Consumption Stand by | 0.5 Watt | Energy Consumption per Year | 125 kWh | Dimensions (WxDxH) - without stand | 109.47 cm x 10.42 cm x 63.81 cm | Weight | 14.2 kg |
General | |
Curved Screen | Yes (3000R) |
Series | 6 Series |
HDR Capable | Yes |
Video Processor | Quad-Core |
TV Tuner Presence | Yes |
Extended PVR | Yes |
Sensors | Eco Sensor |
Modes | Game mode, Film Mode |
Design | Very Narrow Bezel Design (VNB), Y-Shape Design |
Dimensions | Without stand |
Width | 109.47 cm |
Depth | 10.42 cm |
Height | 63.81 cm |
Weight | 14.2 kg |
Enclosure Colour | Silver |
Display | |
Display Menu Language | Multilingual |
Features | Time-shift, HDMI quick switch, Auto Motion Plus, E-Manual, Instant On, Embeded POP, Accessibility Enlarge, Accessibility Voice guide |
Stands & Mounts | |
Stand | Included |
Stand Design | Tabletop |
Flat Panel Mount Interface | Yes |
TV Tuner | |
Conditional Access | Common Interface Plus (CI+) slot |
Digital TV Tuner | |
HDTV Tuner | Yes |
Video Features | |
Electronic Programme Guide | Digital EPG |
Media Player | |
USB Port | Yes |
USB Ports Qty | 2 |
Remote Control | |
Type | Remote control |
Remote Control Model | Samsung TM1750A |
Features | Additional remote control included, Samsung Smart Control included |
Audio System | |
Digital Audio Format | DTS digital output, Dolby Digital Plus output |
Output Power / Total | 20 Watt |
Features | Down-firing Speaker, Audio Return Channel (ARC), Voice Interaction, Bass Reflex Speaker System |
Speakers | 2 x speaker - 10 Watt |
Network & Internet Multimedia | |
Functionality | Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback |
LAN Protocol | Ethernet |
Connect & Share | Wi-Fi Direct, Screen Mirroring, USB Human Interface Device (HID), ConnectShare, Bluetooth Human Interface Device (HID) |
Supported Consumer Electronics Control (CEC) | Anynet Plus, Multiroom Link |
DLNA | Yes |
Connections | |
Connector Type | 3 x HDMI , 2 x USB 2.0 , Composite video / component video input , LAN , Digital audio output (optical) , Audio line-in |
Miscellaneous | |
Included Accessories | Batteries |
Power | |
Power Device | Power supply |
Input Voltage | AC 230V (50/60 Hz) |
Auto On/Off | Yes |
Dimensions & Weight Details | |
Dimensions & Weight Details | Panel without stand - 109.47 cm x 10.42 cm x 63.81 cm x 14.2 kg , Panel with stand - 109.47 cm x 33.43 cm x 70.82 cm x 16.1 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 124.9 cm |
Depth (Shipping) | 20.7 cm |
Height (Shipping) | 74.4 cm |
Weight (Shipping) | 20.3 kg |
