Discover the detail of stunningly realistic UHD picture quality
The Samsung UE590 UHD monitor offers PC viewing, gaming and more, all in stunning Ultra HD picture quality. Superb images that boast a staggering 8 million pixels are delivered at a resolution 4x greater than Full HD. See your 4K content the way it was meant to be seen, with realistic detail that makes you feel like you’re really there. Experience a new level of clarity in Ultra High Definition.
Take your entertainment to new heights of immersion and comfort
Experience incredibly vibrant colour and high brightness level
Powerful multitasking features for maximum productivity
Enhanced connectivity with a triple interface
The UE590 features a hardware interface with useful and advanced connections to maximise your gaming experience. It provides seamless connectivity with your PC and AV equipment with DisplayPort 1.2 and 2 different HDMI ports making it the perfect partner for your game console as well as your PC.
Sophisticated design in matte black & T-shaped stand with a metallic touch
Easy on the eyes for a more comfortable viewing experience
Product Description | Samsung U24E590D - UE590 Series - LED monitor - 24" | Device Type | LED-backlit LCD monitor - 24" | Energy Class | Class C | Energy Consumption per Year | 61 kWh | Power Consumption (On mode) | 42 W | Adaptive-Sync Technology | AMD FreeSync | Panel Type | Plane to Line Switching (PLS) | Aspect Ratio | 16:9 | Native Resolution | 4K UHD (2160p) 3840 x 2160 at 60 Hz | Pixel Pitch | 0.13575 mm | Brightness | 300 cd/m² | Response Time | 4 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | 2xHDMI, DisplayPort | Display Position Adjustments | Tilt | Voltage | AC 120/230 V | Colour | Black, metallic silver | Dimensions (WxDxH) - with stand | 56.11 cm x 18.71 cm x 42.8 cm | Weight | 4.61 kg | Environmental Standards | ENERGY STAR Qualified |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Viewable Size | 23.5" |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Picture in picture, picture by picture, game mode, Mega Dynamic Contrast Ratio, Flicker Free technology, Eye Saver Mode |
Dimensions (WxDxH) | 56.11 cm x 18.71 cm x 42.8 cm - with stand |
Weight | 4.61 kg |
Connectivity | |
Interfaces | Headphones , 2 x HDMI , DisplayPort |
Mechanical | |
Tilt Angle | -2/+20 |
VESA Mounting Interface | 75 x 75 mm |
Miscellaneous | |
Cables Included | 1 x HDMI cable , 1 x DisplayPort cable |
Power | |
Power Supply | External |
Input Voltage | AC 120/230 V |
Power Consumption (Typical) | 45 Watt |
Power Consumption Stand by | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 56.11 cm - depth: 18.71 cm - height: 42.8 cm - weight: 4.61 kg , Without stand - width: 56.11 cm - depth: 6.28 cm - height: 33.3 cm - weight: 4.04 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
