With a Samsung SA450 business monitor, you'll discover more comfortable viewing and greater energy-efficiency. Optimise your viewpoint by making adjustments to height, perspective and tilt that can benefit your posture as well as productivity. Moving and setting up your SA450 is easier too, with its lightweight and innovative design. Features like cable arrangement and the detachable adaptor also help you minimise clutter and maximise space. It's more energy efficient when in use and even allows you to reduce power consumption when it's not, thanks to the Adaptor On Off switch.
Product Description | Samsung S24A450BW - LED monitor - 24" | Device Type | LED-backlit LCD monitor - 24" | Native Resolution | 1920 x 1200 | Pixel Pitch | 0.27 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 / 5000000:1 (dynamic) | Response Time | 5 ms | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA | Display Position Adjustments | Height, pivot (rotation), tilt | Colour | Matte black | Dimensions (WxDxH) - with stand | 56 cm x 20.1 cm x 40 cm | Weight | 6.7 kg | Microsoft Certification | Compatible with Windows 7 | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | TUV GS, DDC-2B, ISO 9241-307 | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Vertical Refresh Rate | 61 Hz |
Horizontal Refresh Rate | 75 kHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | LED backlight |
Features | Power off timer, MagicColor, HDCP, MagicAngle, MagicBright 3 |
Dimensions (WxDxH) | 56 cm x 20.1 cm x 40 cm - with stand |
Weight | 6.7 kg |
Connectivity | |
Interfaces | VGA , DVI-D |
Mechanical | |
Tilt Angle | 25 |
Height Adjustment | 100 mm |
Miscellaneous | |
Features | Wall mountable |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Power | |
Power Supply | External |
Power Consumption (Typical) | 29 Watt |
Power Consumption Stand by / Sleep | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 56 cm - depth: 20.1 cm - height: 40 cm - weight: 6.7 kg , Without stand - width: 56 cm - depth: 5 cm - height: 37.4 cm - weight: 5.1 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 63.8 cm |
Shipping Depth | 20 cm |
Shipping Height | 45.3 cm |
Shipping Weight | 6.7 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years - pick-up and return |
