With a host of features to enhance the user experience, such as the Height Adjustable Stand (HAS), this monitor offers a truly personalized experience. The advanced LED monitors also minimized running costs, which is also good for the environment. So, if you are serious about working, then this is the perfect choice.
Product Description | Samsung S22C450BW - SC450 Series - LED monitor - 22" | Device Type | LED-backlit LCD monitor - 22" | Panel Type | TN | Aspect Ratio | 16:10 | Native Resolution | 1680 x 1050 | Pixel Pitch | 0.282 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Response Time | 5 ms | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Matte black | Dimensions (WxDxH) - with stand | 50.24 cm x 21 cm x 45.35 cm | Weight | 5 kg | Microsoft Certification | Compatible with Windows 7 | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 22" |
Panel Type | TN |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | LED backlight |
Features | Power off timer, MagicTune, MagicRotation, MagicAngle, MagicBright 3, Mega Dynamic Contrast Ratio, Eco Saving |
Dimensions (WxDxH) | 50.24 cm x 21 cm x 45.35 cm - with stand |
Weight | 5 kg |
Connectivity | |
Interfaces | VGA , DVI-D |
Mechanical | |
Tilt Angle | -3/+25 |
Swivel Angle | 90 |
Rotation Angle | -1/+95 |
Height Adjustment | 100 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Cables Included | 1 x VGA cable |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Power | |
Power Supply | Internal |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 24 Watt |
Power Consumption Stand by / Sleep | 0.1 Watt |
Software / System Requirements | |
Included Software | Drivers & Utilities, Samsung MultiScreen |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 50.24 cm - depth: 21 cm - height: 45.35 cm - weight: 5 kg , Without stand - width: 50.24 cm - depth: 5.55 cm - height: 32.98 cm - weight: 3.5 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% |
