If you're looking for a reliable business notebook then look no further than the Samsung Series 4 notebook - expertly engineered for superior usability, craftsmanship and performance. Plus there's an anti-reflective screen that's up to 40% brighter than conventional displays, so it's much easier to use for longer - even outdoors - without your eyes getting tired. And for maximum ease of use there's a host of ergonomic features like a responsive keyboard, that feels as comfortable as using a desktop keyboard, plus a much larger touchpad. So the Samsung Series 4 notebook simply adds up to greater productivity, long-lasting performance and less work for your IT department.
Product Description | Samsung Series 4 400B5B - 15.6" - Core i5 2550M - 4 GB RAM - 500 GB HDD | Product Type | Notebook | Operating System | Win 7 Pro 64-bit | Processor | Intel Core i5 (2nd Gen) 2550M / 2.5 GHz (3.1 GHz) | Memory | 4 GB DDR3 (2 x 2 GB) | Storage | 500 GB HDD | Optical Drive | DVD SuperMulti | Display | 15.6" LED backlight 1366 x 768 / HD | Graphics | Intel HD Graphics | Integrated Webcam | Yes | Networking | 802.11a/b/g/n, Bluetooth 2.1 | Battery | 6-cell | Features | Stereo speakers | Dockable | Yes | Security | Trusted Platform Module (TPM) Security Chip, fingerprint reader | Dimensions (WxDxH) | 37 cm x 24.83 cm x 3.53 cm | Weight | 2.5 kg | Microsoft Office Preloaded | Includes a pre-loaded image of select Microsoft Office 2010 suites. Purchase an Office 2010 Product Key Card or disc to activate preloaded software on this PC. | Localisation | Region: United Kingdom | Environmental Standards | ENERGY STAR Qualified EPEAT Gold | Manufacturer Warranty | Limited warranty - 5 years |
General | |
Operating System | Microsoft Windows 7 Professional 64-bit Edition |
Processor / Chipset | |
CPU | Intel Core i5 (2nd Gen) 2550M / 2.5 GHz |
Max Turbo Speed | 3.1 GHz |
Number of Cores | Dual-Core |
64-bit Computing | Yes |
Chipset | Mobile Intel HM65 Express |
Features | Hyper-Threading Technology, Intel Turbo Boost Technology 2.0 |
Memory | |
RAM | 4 GB (2 x 2 GB) |
Max RAM Supported | 8 GB |
Technology | DDR3 SDRAM |
Speed | 1333 MHz / PC3-10600 |
Rated Speed | 1333 MHz |
Form Factor | SO-DIMM 204-pin |
Slots Qty | 2 |
Empty Slots | 0 |
Storage | |
Main Storage | 500 GB HDD SATA 3Gb/s |
Optical Drive | DVD±RW (±R DL) / DVD-RAM |
Display | |
Type | 15.6" |
LCD Backlight Technology | LED backlight |
Resolution | 1366 x 768 (HD) |
Widescreen | Yes |
Image Aspect Ratio | 16:9 |
Features | SuperBright, anti-reflective |
Audio & Video | |
Graphics Processor | Intel HD Graphics |
Memory Allocation Technology | Dynamic Video Memory Technology 5.0 |
Camera | Yes |
Resolution | 1.3 Megapixel |
Sound | Microphone |
Compliant Standards | High Definition Audio, SoundAlive |
Input | |
Type | Keyboard, touchpad |
Features | Spill-resistant |
Communications | |
Wireless | 802.11a/b/g/n, Bluetooth 2.1 |
Compliant Standards | IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, Bluetooth 2.1 |
Battery | |
Technology | 6-cell |
Installed Qty | 1 |
Capacity | 5900 mAh |
AC Adapter | |
Input | AC 120/230 V (50/60 Hz) |
Output | 60 Watt, 19 V, 3.16 A |
Connections & Expansion | |
Slots | 1 x ExpressCard/34 , 2 x memory (0 free) |
Interfaces | VGA , HDMI , Headphone output , Microphone input , 2 x USB 2.0 , USB 3.0 , LAN , Dock |
Memory Card Reader | 7 in 1 (SD Card, Memory Stick, Memory Stick PRO, MultiMediaCard, xD-Picture Card, MMCplus, SDHC Card) |
Software | |
Software Included | Adobe Acrobat Reader, Samsung Update Plus, SAMSUNG Support Center, Samsung Recovery Solution, Samsung Easy Battery Manager, Samsung Easy Network Manager, Samsung Easy Display Manager, Samsung Easy File Share, Norton Internet Security (60 days trial), Samsung Free Fall Sensor |
Miscellaneous | |
Integrated Options | Stereo speakers |
Dockable | Yes |
Features | Security lock slot (cable lock sold separately), system password, hard drive password |
Included Accessories | Power adapter |
Localization | Region: United Kingdom |
Dimensions & Weight | |
Weight | 2.5 kg |
Sustainability Information | |
EPEAT Compliant | EPEAT Gold |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
