Enjoy a wider world of entertainment. You can connect your mobile devices to the Samsung S27B550V monitor and enjoy your favourite content in Full HD clarity on a bigger screen. Wider viewing angles also give great viewing whether you're sitting, standing or lying down on the sofa. A broader range of inputs, including HDMI and DVI, gives you great connectivity for games consoles, Blu-ray players and more. With built-in stereo speakers, you can also enjoy great sound as well as more space.
Product Description | Samsung S27B550V - LED monitor - Full HD (1080p) - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class B | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Brightness | 300 cd/m² | Contrast Ratio | 1000:1 / 5000000:1 (dynamic) | Response Time | 2 ms | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA | Speakers | Integrated | Display Position Adjustments | Tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Black | Dimensions (WxDxH) - with stand | 65 cm x 25.2 cm x 46.7 cm | Weight | 4.6 kg | Microsoft Certification | Compatible with Windows 7 | Environmental Standards | ENERGY STAR Qualified EPEAT Gold |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | LED backlight |
Features | Power off timer, MagicTune, MagicColor, MagicAngle, MagicBright 3, Touch of Color (ToC), Mega Dynamic Contrast Ratio, Mobile High-Definition Link (MHL) |
Colour | Black |
Dimensions (WxDxH) | 65 cm x 25.2 cm x 46.7 cm - with stand |
Weight | 4.6 kg |
Audio | |
Type | Speakers - stereo - integrated |
Output Power / Channel | 10 Watt |
Connectivity | |
Interfaces | VGA , 2 x HDMI , Audio line-in/out |
Mechanical | |
Miscellaneous | |
Features | Wall mountable |
Cables Included | 1 x VGA cable |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Power | |
Power Supply | External |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 50 Watt |
Power Consumption Stand by / Sleep | 0.5 Watt |
Power Consumption Stand by | 0.5 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 65 cm - depth: 25.2 cm - height: 46.7 cm - weight: 4.6 kg , Without stand - width: 65 cm - depth: 5.8 cm - height: 39.4 cm - weight: 4.2 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 73.1 cm |
Shipping Depth | 13.2 cm |
Shipping Height | 47.7 cm |
Shipping Weight | 6.5 kg |
Sustainability Information | |
EPEAT Compliant | EPEAT Gold |
ENERGY STAR Certified | Yes |
