Samsung S24E450BL 23.6" 1920x1080 5ms VGA DVI LED Monitor
Key features
  • Environmentally friendly
  • Impressive picture quality
  • Slim design that fits any desk
  • Ergonomic, adjustable stand
  • Fast, easy connectivity
Product codes
chevron icon
chevron icon
The SE450 series provides an environmentally friendly, user friendly and budget friendly yet high quality desktop monitor solution for your business. Features include a simple and easy to use design, fully adjustable stand, matte black bezel with clearly labeled buttons, versatile connectivity and a low-glare commercial-grade TN panel.
chevron icon
Product Description Samsung S24E450BL - SE450 Series - LED monitor - Full HD (1080p) - 23.6"
Device Type LED-backlit LCD monitor - 23.6"
Energy Class Class G
Power Consumption (On mode) 27 W
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.2715 mm
Brightness 300 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms
Colour Support 16.7 million colours
Colour Gamut 72% (CIE 1976)
Input Connectors DVI, VGA
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Voltage AC 120/230 V
Colour Black
Dimensions (WxDxH) - with stand 55.46 cm x 22.4 cm x 35.23 cm
Weight 5.48 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards TUV, C-Tick, EN55022, SASO, EN55024, CB, FCC Part 15 B, CCC, IC, PSB, AS/NZS 3548, FCC, IEC 60950-1, EN 60950-1, KCC, cULus, KC, KUCAS, SONCAP, GB 9254-2008, KN22, KN24, K60950-1, UL60950-1, GB 4943-2011, GB 17625.1-2012
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
