Maximized your viewing and your workspace. The Samsung Series 2 LED Business Monitor features a stylish narrow bezel to make the most of the screen and reduce distraction. Thanks to its compact space-saving design, you can also use your workspace better and keep it tidy. To help you reduce business costs, it's more energy-efficient too, consuming just 0.1 watts of electricity when in standby mode. You can even use the VESA Wall Mount to hang it securely and make the most of your space.
Product Description | Samsung S24C200BL - LED monitor - Full HD (1080p) - 23.6" | Device Type | LED-backlit LCD monitor - 23.6" | Panel Type | TN | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Pixel Pitch | 0.2715 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Response Time | 5 ms | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA | Display Position Adjustments | Tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Matte black | Dimensions (WxDxH) - with stand | 55.46 cm x 18.5 cm x 41.23 cm | Weight | 4.1 kg | Microsoft Certification | Compatible with Windows 7 | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.6" |
Panel Type | TN |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | LED backlight |
Features | Power off timer, MagicTune, MagicAngle, MagicBright 3, Mega Dynamic Contrast Ratio, Eco Saving |
Dimensions (WxDxH) | 55.46 cm x 18.5 cm x 41.23 cm - with stand |
Weight | 4.1 kg |
Connectivity | |
Interfaces | VGA , DVI-D |
Mechanical | |
Tilt Angle | -1/+20 |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Compatible with Windows 7 | "Compatible with Windows 7" software and devices carry Microsoft’s assurance that these products have passed tests for compatibility and reliability with 32-bit and 64-bit Windows 7. |
Power | |
Power Supply | Internal |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 30 Watt |
Software / System Requirements | |
Included Software | Samsung MultiScreen |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 55.46 cm - depth: 18.5 cm - height: 41.23 cm - weight: 4.1 kg , Without stand - width: 55.46 cm - depth: 7.7 cm - height: 33.05 cm - weight: 3.75 kg |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% |
