The Samsung LED Monitor Series 3 does all the work you need in just the right manner. Functional and with a stylish design, this monitor is all you need.
Choose a monitor that fulfils all your functional needs and with picture quality that you will love. The Samsung LED Monitor Series 3 sports a stylish design with its black high glossy looks and is guaranteed to complement any environment it's in. Experience real color with mega DCR and get better picture quality with magic upscale.
Product Description | Samsung S22C300B - SC300 Series - LED monitor - Full HD (1080p) - 21.5" | Device Type | LED-backlit LCD monitor - 21.5" | Energy Class | Class C | Panel Type | TN | Native Resolution | Full HD (1080p) 1920 x 1080 at 60 Hz | Pixel Pitch | 0.248 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Response Time | 5 ms | Colour Support | 16.7 million colours | Input Connectors | DVI-D, VGA | Display Position Adjustments | Tilt | Voltage | AC 120/230 V (50/60 Hz) | Colour | Transparent red | Dimensions (WxDxH) - with stand | 51 cm x 19.5 cm x 39.8 cm | Weight | 2.9 kg | Environmental Standards | ENERGY STAR Qualified EPEAT Gold | Compliant Standards | DDC-2B, ISO 9241-307 | Manufacturer Warranty | 2-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 21.5" |
Panel Type | TN |
Vertical Refresh Rate | 56 - 61 Hz |
Horizontal Refresh Rate | 30 - 75 kHz |
Horizontal Viewing Angle | 170 |
Vertical Viewing Angle | 160 |
Backlight Technology | LED backlight |
Features | MagicBright, power off timer, MagicTune, MagicAngle, Mega Dynamic Contrast Ratio, Eco Saving |
Dimensions (WxDxH) | 51 cm x 19.5 cm x 39.8 cm - with stand |
Weight | 2.9 kg |
Connectivity | |
Interfaces | VGA , DVI-D (HDCP) |
Mechanical | |
Miscellaneous | |
Cables Included | 1 x VGA cable |
Power | |
Power Supply | External |
Input Voltage | AC 120/230 V (50/60 Hz) |
Power Consumption (Typical) | 22 Watt |
Power Consumption Stand by | 0.3 Watt |
Power Consumption Sleep | 0.3 Watt |
Software / System Requirements | |
Included Software | Samsung MultiScreen |
OS Required | Apple MacOS, Windows 8 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 51 cm - depth: 19.5 cm - height: 39.8 cm - weight: 2.9 kg , Without stand - width: 51 cm - depth: 5.3 cm - height: 31.9 cm - weight: 2.6 kg |
Sustainability Information | |
EPEAT Compliant | EPEAT Gold |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
