The sophisticated Ring Radiator technology in Samsung's Wireless Multiroom Speakers with 360 Sound is designed to disperse sound in all directions, to create an immersive audio experience in your living space. Connect multiple 360 Sound Speakers over your existing Wi-Fi network to create a Samsung Wireless Multiroom System, and enjoy superb music throughout your home. Stream one song to many rooms at once, play different songs in each connected room at the same time, and control it all from your compatible smartphone or tablet.
Product Description | Samsung Multiroom WAM1500 - speaker - wireless | Product Type | Speaker | Speaker Type | 2-way - active | Amplifier | Integrated | Interfaces | Bluetooth, Wi-Fi | Audio Formats | WAV, WMA, AAC, AIFF, MP3, FLAC, OGG, ALAC | Sound Effects | 360° sound | Dimensions (WxDxH) | 12.3 cm x 12.3 cm x 23.2 cm | Weight | 1.4 kg |
General | |
Speaker System | |
Bluetooth Profiles | Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Low Complexity Subband Coding (SBC) |
Controls | Mute, power on/off, volume, play/pause, next track, previous track |
Speaker System Details | |
Driver Details | Speaker: tweeter driver - 0.98" , Speaker: woofer driver - 3.46" |
Miscellaneous | |
Included Accessories | Power adapter, power cable |
Power | |
Power Source | AC power adapter |
Power Consumption Operational | 10 Watt |
Dimensions & Weight | |
Width | 12.3 cm |
Depth | 12.3 cm |
Height | 23.2 cm |
Weight | 1.4 kg |
