75" MU6100 Ultra HD certified HDR Smart TV
Product Description | Samsung UE75MU6100K 6 Series - 75" LED-backlit LCD TV - 4K | Product Type | LED-backlit LCD TV - Smart TV | Diagonal Class | 75" | Colour | Black | Resolution | 3840 x 2160 | Display Format | 4K UHD (2160p) | Frame Rate & Enhancement Technology | 1300 Picture Quality Index | Video Interface | Component, composite, HDMI | HDMI Ports Qty | 3 ports | Connectivity | Wi-Fi, LAN, Bluetooth | LCD Backlight Technology | LED backlight UHD dimming | Image Aspect Ratio | 16:9 | TV Tuner | 1x analogue, 1x digital | Digital TV Tuner | DVB-C, DVB-T2 | Internet Streaming Services | Smart Hub, HbbTV | Picture Enhancements | Digital Clean View, Mega Contrast, Ultra Clean View, contrast enhancer, UHD Upscaling, PurColor | Speaker System | 2 speakers | USB | 2 ports | Included Accessories | Samsung TM1750A remote control, batteries | Voltage | AC 230V (50/60 Hz) | Energy Class | Class A | Power Consumption Operational | 355 Watt | Power Consumption (On mode) | 205 W | Power Consumption Stand by | 0.5 Watt | Energy Consumption per Year | 284 kWh | Dimensions (WxDxH) - without stand | 168.89 cm x 6.6 cm x 97.12 cm | Weight | 35.2 kg |
General | |
Series | 6 Series |
HDR Capable | Yes |
Video Processor | Quad-Core |
TV Tuner Presence | Yes |
Extended PVR | Yes |
Sensors | Eco Sensor |
Modes | Game mode, Film Mode |
Design | Very Narrow Bezel Design (VNB), Refined Design |
Dimensions | Without stand |
Width | 168.89 cm |
Depth | 6.6 cm |
Height | 97.12 cm |
Weight | 35.2 kg |
Enclosure Colour | Black |
Display | |
Display Menu Language | Multilingual |
Features | Time-shift, HDMI quick switch, Auto Motion Plus, E-Manual, Instant On, Embeded POP, MBR Support |
Stands & Mounts | |
Stand | Included |
Stand Design | Tabletop |
Flat Panel Mount Interface | Yes |
TV Tuner | |
Conditional Access | Common Interface Plus (CI+) slot |
Digital TV Tuner | |
HDTV Tuner | Yes |
Video Features | |
Electronic Programme Guide | Digital EPG |
Media Player | |
USB Port | Yes |
USB Ports Qty | 2 |
Remote Control | |
Type | Remote control |
Remote Control Model | Samsung TM1750A |
Features | Samsung Smart Control included |
Audio System | |
Digital Audio Format | DTS digital output, Dolby Digital Plus output |
Output Power / Total | 20 Watt |
Features | Down-firing Speaker, Audio Return Channel (ARC), Bass Reflex Speaker System |
Speakers | 2 x speaker - 10 Watt |
Network & Internet Multimedia | |
Functionality | Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback |
LAN Protocol | Ethernet |
Connect & Share | Wi-Fi Direct, USB Human Interface Device (HID), Samsung Smart View, ConnectShare, Bluetooth Human Interface Device (HID) |
Supported Consumer Electronics Control (CEC) | Anynet Plus, Multiroom Link |
DLNA | Yes |
Connections | |
Connector Type | 3 x HDMI , 2 x USB , Composite video / component video input , LAN , Digital audio output (optical) |
Miscellaneous | |
Included Accessories | Batteries |
Power | |
Power Device | Power supply |
Input Voltage | AC 230V (50/60 Hz) |
Auto On/Off | Yes |
Dimensions & Weight Details | |
Dimensions & Weight Details | Panel without stand - 168.89 cm x 6.6 cm x 97.12 cm x 35.2 kg , Panel with stand - 168.89 cm x 38.49 cm x 105.26 cm x 38.8 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 188.6 cm |
Depth (Shipping) | 25.8 cm |
Height (Shipping) | 113.8 cm |
Weight (Shipping) | 53.2 kg |
