Amazing sound with a beautifully soft curved design, this soundbar is the perfect match for your TV. Audibly remarkable, visually appealing.
Product Description | Samsung HW-M4501 - sound bar system - for home theatre - wireless | Product Type | Sound bar system - for home theatre - 2.1-channel | System Components | Subwoofer, sound bar | Speaker Type | Active | Nominal Output Power (Total) | 260 Watt | Frequency Response | 45 - 20000 Hz | Amplifier | Integrated | Interfaces | Bluetooth | Audio Formats | WAV, WMA, AAC, MP3, FLAC, OGG | Speaker System Details | 1 x subwoofer 130 Watt 3 Ohm , 1 x sound bar 130 Watt 6 Ohm | Colour | Silver | Built-in Decoders | Dolby Digital, DTS Digital Surround | Sound Effects | Surround Sound Expansion | Environmental Standards | ENERGY STAR Qualified | Manufacturer Warranty | 1-year warranty |
General | |
Enclosure Colour | Silver |
Design Features | Curved |
Speaker System | |
Audio System Continuous Power (Total) | 260 Watt |
Speaker System Details | |
Speakers Included | 1 x subwoofer - 130 Watt - 3 Ohm - wall-mountable - wireless , 1 x sound bar - 130 Watt - 6 Ohm |
Driver Details | Subwoofer: subwoofer driver - 6.5" |
Connections | |
Connector Type | HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , Audio line-in (mini-phone stereo 3.5 mm) , SPDIF input (TOS Link) |
Miscellaneous | |
Included Accessories | Digital audio cable (optical), remote control, wall mounting bracket |
Sustainability Information | |
ENERGY STAR Certified | Yes |
Dimensions & Weight | |
Dimensions (WxDxH) / Weight Details | Sound bar: 107.8 cm x 12.9 cm x 4.75 cm / 2.7 kg , Subwoofer: 17.9 cm x 29.95 cm x 35.3 cm / 4.6 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
