Samsung HW-K850 Cinematic Up-firing 3.1.2 Wireless Smart Soundbar with Dolby Atmos
More really is more
Hear pristine sound, even the minute details. With 11 built-in speakers, each with its own dedicated amplifier, the HW-K850 immerses you in incredibly clear sound from the very last raindrop to the complex symphony of the orchestra. The height channel of the specialised upfiring speakers will surround you with richer, more multi-dimensional audio.
Above and beyond
Multi-dimensional cinematic sound is no longer just for movie theaters. The HW-K850 gives you incredible 3.1.2 channel sound that doesn’t just surround you, it puts you deep into the action.
From ordinary to exceptional surround
Three words: dynamic movie night. Surround Sound Expansion Plus lets you upmix any content to enjoy in 3.1.2ch surround sound. Feel the sound come from all around and overhead as if you’re in the theatre. So, choose any movie, pick a night, and prepare to be blown away.
Sweet anywhere you sit
Finding the sweet spot just got a lot easier. With a wide-range tweeter, engineered by the Samsung Audio Lab, you’ll get consistently great sound wherever you sit. So even if you didn’t score the best seat in the room, you won’t miss a single decibel.
Get real, with HD Audio
Feel the sound and get into the action with stunningly realistic HD Audio. It preserves the quality and richness of the original sound using 96 ~ 192kHz/24bit sampling.
Product Description | Samsung HW-K850 - sound bar system - for home theatre - wireless | Product Type | Sound bar system - for home theatre - 3.1.2-channel | System Components | Subwoofer, sound bar | Speaker Type | Active | Nominal Output Power (Total) | 360 Watt | Amplifier | Integrated | Interfaces | Bluetooth, Wi-Fi | DLNA | Yes | Streaming Services | Deezer, Napster, Spotify, TuneIn, JUKE, Murfie, Qobuz, 7Digital | Audio Formats | WAV, WMA, AAC, AIFF, MP3, FLAC, OGG, ALAC | Speaker System Details | 1 x sound bar 198 Watt , 1 x subwoofer 162 Watt | Speaker Details | Sound bar 11 - 18 Watt - 10% THD - 4 Ohm - active , Speaker - subwoofer - 162 Watt - 10% THD - 3 Ohm - active | Colour | Black | Built-in Decoders | Dolby Digital Plus, Dolby TrueHD, DTS Digital Surround, Dolby Atmos | Manufacturer Warranty | 2-year warranty |
General | |
Enclosure Colour | Black |
Speaker System | |
Audio System Continuous Power (Total) | 360 Watt |
Maximum Sampling Rate Supported | 192 kHz (WAV, FLAC) |
High-Resolution Audio | Yes |
Multiroom | Yes |
DLNA | Yes |
Internet Streaming Services | Deezer, Napster, Spotify, TuneIn, JUKE, Murfie, Qobuz, 7Digital |
Controls | Input selector, power on/off, volume |
Speaker System Details | |
Speakers Included | 1 x sound bar - 198 Watt - wall-mountable , 1 x subwoofer - 162 Watt - wireless |
Driver Details | Subwoofer: subwoofer driver - 8" |
Driver Details (2nd speaker) | Sound bar: 11 |
Connections | |
Connector Type | 2 x HDMI input (19 pin HDMI Type A) , HDMI output (19 pin HDMI Type A) , Digital audio input (optical) (TOS Link) , Service (5 pin Micro-USB Type B) |
Miscellaneous | |
Included Accessories | Mounting hardware, AC power adaptor, remote control, power cable, HDMI cable, batteries, wall mounting bracket |
Dimensions & Weight | |
Dimensions (WxDxH) / Weight Details | Sound bar: 121.02 cm x 13.14 cm x 8.17 cm / 6.7 kg , Subwoofer: 20.39 cm x 41.43 cm x 39.9 cm / 9.6 kg |
Dimensions & Weight (Shipping) | |
Shipping Weight | 20.7 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
