ITEM | QTY | PRICE |
StarTech.com USB-C Multiport Adapter...
3 | £150.39 |
Tab A7 Lite
£109.00
8.7" / 4G
Grade A Returned Device
Looking for your next phone or tablet, but want to make your money go further? Try one of our Grade A devices and you’ll find amazing deals on some of the latest and greatest devices.
Meet the Galaxy Tab A7 Lite, the tablet that's made to be shared. With a compact screen, sturdy metal frame, powerful performance and plenty of storage, your whole family will love it.
Designed to go where you do
Don't sacrifice style for convenience. Galaxy Tab A7 Lite gives you both in a slim package. Measuring a thin 8.0mm and weighing 371g, this highly portable tablet packs easily into your bag and doesn't hold you back with heaviness.
Simple gestures for one-handed use
Easily navigate your tablet with one hand. A gesture-based menu allows you to do things like go back, see your recent apps and return to the home menu all with a swipe of your thumb. With dozens of functions, Galaxy Tab A7 Lite puts convenience at your fingertips.
A camera to capture your live moments
The Galaxy Tab A7 Lite camera is ready to capture and share your moment. Whether you're looking to capture stunning portraits or breathtaking scenery, this device has you covered. With an 8MP main camera, your memories stay vivid, bright and clear.
The nearest theatre is where you are
Less bezel means more room for a bigger 8.7 inch display on a conveniently compact tablet. Enjoy an impromptu private screening in the park or binge watch in bed with dual speakers in landscape orientation that deliver rich stereo sound.
Store more of what you love
Galaxy Tab A7 Lite comes with 32GB storage built in for all your high-resolution videos, photos and files. You can then expand it with a microSD card for even more storage — up to 1TB. Store more of what you love and delete less.
Battery life that stands out from the pack
Galaxy Tab A7 Lite carries more power than you'd expect in a device this sleek. The 5,100mAh battery gives you the freedom to forget about the charger for long periods of time when you have somewhere to go or lots to watch.
Trade in your old device.
Got an old phone, tablet or smartwatch lying around?
When you trade in your old device at EE you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | Samsung Galaxy Tab A7 Lite - tablet - Android - 32 GB - 8.7" - 3G, 4G | Product Type | Tablet | Operating System | Android | Display | 8.7" TFT - 1340 x 800 - Multi-Touch | Processor | (8-core) | Processor Clock Speed | 2.3 GHz | Storage | 32 GB | RAM | 3 GB | User Available Memory | Flash: 19.5 GB | Supported Flash Memory Cards | microSD, microSDHC, microSDXC | Cellular Technology | 3G, 4G | Cellular Protocols | GSM, UMTS, FDD LTE, TDD LTE | Wireless Connectivity | 802.11a/b/g/n/ac, Bluetooth 5.0 | Rear Camera | 8 Megapixel focus: automatic | Front Camera | 2 Megapixel | Navigation System | GPS/GLONASS/Galileo/BeiDou | Dimensions (WxDxH) | 12.47 cm x 0.8 cm x 21.25 cm | Weight | 371 g | Colour | Grey | SAR | 0.99 W/kg (body), 0.64 W/kg (head) |
General | |
Display | |
Type | 8.7" TFT |
Resolution | 1340 x 800 |
Colour Depth | 16 million colours |
Touchscreen | Multi-Touch |
Processor | |
Number of Cores | 8-core |
Memory | |
Storage | 32 GB |
RAM | 3 GB |
Max Supported Capacity | 1 TB |
Communications | |
Band | GSM 850/900/1800/1900 / UMTS 850/900/AWS/1900/2100 / LTE 700/800/850/900/AWS/AWS-3/1800/1900/2100/2300/2600 |
Security Protocols & Features | Wi-Fi Direct |
Bluetooth Profiles | Hands-Free Profile (HFP), Headset Profile (HSP), Object Push Profile (OPP), Personal Area Networking Profile (PAN), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP), Human Interface Device Profile (HID), Phonebook Access Profile (PBAP), Message Access Profile (MAP), HID Over GATT Profile (HOGP) |
Rear Camera | |
Sensor Resolution | 8 Megapixel |
Focus Adjustment | Automatic |
Lens Aperture | F/2.0 |
Video Resolutions | 1920 x 1080 (1080p) at 30 fps |
Front Camera | |
Sensor Resolution | 2 Megapixel |
Lens Aperture | F/2.2 |
Navigation System | |
Receiver | GPS/GLONASS/Galileo/BeiDou |
Multimedia | |
Supported Digital Audio Standards | WAV, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA, MID |
Supported Digital Video Standards | MPEG-4, AVI, MKV, 3GP, FLV, 3G2, M4V, WEBM |
Audio | Microphone, stereo speakers |
Software | |
Preloaded Software | Samsung KNOX, Samsung Smart Switch |
Expansion and Connectivity | |
Expansion Slots | 1 x microSDXC |
Interfaces | USB-C/USB 2.0 , Headphones mini jack (3.5mm) |
Battery | |
Technology | Lithium Ion |
Capacity | 5100 mAh |
Miscellaneous | |
Colour | Grey |
Case Material | Metal |
Sensors | Accelerometer, geomagnetic sensor, light sensor |
Features | Fast charging |
SAR Value | 0.99 W/kg (body), 0.64 W/kg (head) |
Dimensions & Weight | |
Width | 12.47 cm |
Depth | 0.8 cm |
Height | 21.25 cm |
Weight | 371 g |
