Samsung Galaxy S7 edge brings a new way of thinking about what a phone can do. You defined the possibilities. Rethink what a phone can do.
Trade in your old device.
Got an old phone, tablet or smartwatch lying around?
When you trade in your old device at EE you can have the money transferred directly to your bank account - to offset your upgrade to the latest tech! Simply head to our Trade In site to find out more.
Product Description | Samsung Galaxy S7 edge - black - 4G smartphone - 32 GB - GSM | Product Type | 4G smartphone | Manufacturer Model Number | SM-G935F | Display | OLED display - 2560 x 1440 pixels - 5.5" - 534 ppi - Quad HD Super AMOLED | Features | Heart rate sensor | Processor | 2.3 GHz (8-core) - 64-bit | Memory | RAM 4 GB / 32 GB | Supported Memory Card | microSDXC slot - up to 200 GB | Operating System | Android 6.0 (Marshmallow) with Samsung TouchWiz + EtiquEdge | Main Camera | 12 Megapixel - f/1.7 - focus: automatic | Front Camera | 5 Megapixel - CMOS - wide-angle lens - f/1.7 | Service Provider | Not specified | SIM Card | Nano SIM | Wireless Interface | NFC, Wi-Fi 5, Bluetooth, ANT+/ANT | Security Devices | Fingerprint reader | Messaging Services | WhatsApp, Google+ Hangouts, SMS, MMS | Connectors | 3.5 mm headset jack, Micro-USB | Talk Time | Up to 1620 minutes | Wireless Charging Standards | WPC, PMA | Protection | Dustproof, waterproof | Colour | Black | Dimensions (WxDxH) | 72.6 mm x 7.7 mm x 150.9 mm | Weight | 157 g | Specific Absorption Rate (SAR) | 0.264 W/kg (head) , 0.507 W/kg (body) | SAR Category (Belgium) | B |
General | |
Product Type | Smartphone |
Form Factor | Touch |
Integrated Components | Heart rate sensor |
Width | 72.6 mm |
Depth | 7.7 mm |
Height | 150.9 mm |
Weight | 157 g |
Body Colour | Black |
Body Material | Metal, glass |
SAR Value | 0.507 W/kg (body), 0.264 W/kg (head) |
Cellular | |
Technology | WCDMA (UMTS) / GSM |
Mobile Broadband Generation | 4G |
Operating System | Android 6.0 (Marshmallow) |
User Interface | Samsung TouchWiz + EtiquEdge |
Navigation | GPS, A-GPS, GLONASS, BeiDou |
SIM Card Type | Nano SIM |
Input Device | Multi-touch, capacitive |
Messaging & Internet | |
Supported Email Protocols | POP3, IMAP4 |
Communications | |
Data Transmission | GPRS, EDGE, HSDPA, HSUPA, HSPA+, FDD-LTE, TDD-LTE |
2G Band | 850 GSM, 900 GSM, 1800 GSM, 1900 GSM |
4G LTE Band | Band 1, Band 2, Band 3, Band 4, Band 5, Band 7, Band 8, Band 12, Band 13, Band 17, Band 18, Band 19, Band 20, Band 25, Band 26, Band 28, Band 38, Band 39, Band 40, Band 41 |
4G LTE Frequency | FDD 2100, FDD 1900 PCS, FDD 1800+, FDD 1700 - 2110 AWS, FDD 850, FDD 2600, FDD 900, FDD 700a, FDD 700c, FDD 700b, FDD 800 lower, FDD 800 upper, FDD 800 DD, FDD 1900+, FDD 850+, FDD 700 APT, TDD 2600, TDD 1900, TDD 2300, TDD 2500 |
Wireless Interface | NFC, IEEE 802.11a/b/g/n/ac, Bluetooth 4.2, ANT+/ANT |
Bluetooth Profiles | HFP, HSP, OPP, PAN, A2DP, AVRCP, HID, SAP, PBAP, MAP, HOGP |
Phone Features | |
Phone Functions | Speakerphone, voice control, call timer, conference call, flight mode, voice dialing, vibrating alert |
Sensors | Accelerometer, proximity sensor, barometer, gyro sensor, hall sensor, RGB sensor, geomagnetic sensor |
Additional Features | Multitasking, Easy Mode, MIMO technology, Private Mode, Ultra Power Saving Mode, Screen mirroring, Dual Curved display, Alarm Clock |
Media Player | |
Supported Digital Audio Standards | WAV, WMA, AAC, AMR, MP3, FLAC, XMF, OGG, MIDI, M4A, MXMF, OGA, 3GA, AWB, IMY, RTTTL, RTX, OTA |
Supported Digital Video Standards | MKV, FLV, AVI, MPEG-4, WMV, ASF, 3GP, M4V, WebM, 3G2 |
Processor | |
Clock Speed | 2.3 GHz |
Processor Core Qty | 8-core |
64-bit Architecture | Yes |
Memory | |
RAM | 4 GB |
Internal Memory Capacity | 32 GB |
User Memory | 24.4 GB |
Supported Flash Memory Cards | microSDHC, microSDXC - up to 200 GB |
Front Camera | |
Sensor Resolution | 5 Megapixel |
Sensor Type | CMOS |
Lens Type | Wide-angle lens |
Lens Aperture | F/1.7 |
Camera Modes | Slow motion video, selfie panorama |
Light Source | LED flash |
Main Camera | |
Sensor Resolution | 12 Megapixel |
Optical Image Stabiliser | Optical Image Stabiliser (OIS) |
Focus Adjustment | Automatic |
Camera Modes | Panorama, Pro mode, wide selfie mode, Virtual Shot, HYPERLAPSE, Motion panorama |
HDR Mode | Auto HDR mode |
Light Source | LED light |
Video Resolutions | 3840 x 2160 (4K) |
Features | Selective Focus, Dual Pixel technology, Motion photo, vDIS technology, Spotlight |
Display | |
Type | OLED display |
Technology | Quad HD Super AMOLED |
Diagonal Size | 5.5" |
Display Resolution | 2560 x 1440 pixels |
Display Format | QHD |
Pixel Density | 534 ppi |
Colour Depth | 16.7 million colours |
Connections | |
Connector Type | Micro-USB - 5 pin Micro-USB Type B , Headset jack - mini-phone 3.5mm |
Battery | |
Capacity | 3600 mAh |
Wireless Charging | Yes |
Talk Time | 1620 minutes |
Run Time Details | Talk (WCDMA): up to 1620 min , Active online usage (WCDMA): up to 12 hrs , Active online usage (LTE): up to 15 hrs , Active online usage (Wi-Fi): up to 16 hrs , Playback (video): up to 18 hrs , Playback (Music): up to 55 hrs , Playback (audio (Always On Display Off)): up to 74 hrs |
Miscellaneous | |
Compliant Standards | IP68, HAC (Hearing Aid Compatible) |
Included Accessories | USB adapter, stereo headset, USB cable, power adapter, SIM card removal tool |
Environmental Parameters | |
Max Depth of Water Resistance | 1.5 m |
