Reach max performance of PCIe 4.0. Experience longer-lasting, opponent-blasting speed. The in-house controller's smart heat control delivers supreme power efficiency while maintaining ferocious speed and performance, so you can stay at the top of your game.
Product Description | Samsung 990 PRO MZ-V9P2T0BW - SSD - 2 TB - PCIe 4.0 x4 (NVMe) | Type | Solid state drive - internal | Capacity | 2 TB | Hardware Encryption | Yes | Encryption Algorithm | 256-bit AES | NAND Flash Memory Type | Triple-level cell (TLC) | Form Factor | M.2 2280 | Interface | PCIe 4.0 x4 (NVMe) | Data Transfer Rate | 8 GBps | Features | TRIM support, sleep mode, Auto Garbage Collection Algorithm, Dynamic Thermal Guard protection, Samsung V-NAND 3bit MLC Technology, 2GB LPDDR4 DRAM cache, S.M.A.R.T., NVMe 2.0 | Dimensions (WxDxH) | 22 mm x 80 mm x 2.3 mm | Weight | 9 g | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Solid state drive - internal |
Capacity | 2 TB |
Width | 22 mm |
Depth | 80 mm |
Height | 2.3 mm |
Weight | 9 g |
Performance | |
SSD Endurance | 1200 TB |
Drive Transfer Rate | 8 GBps (external) |
Internal Data Rate | 7450 MBps (read) / 6900 MBps (write) |
4KB Random Read | 1400000 IOPS |
4KB Random Write | 1550000 IOPS |
Reliability | |
MTBF | 1,500,000 hours |
Expansion & Connectivity | |
Compatible Bay | M.2 2280 |
Power | |
Power Consumption | 5.8 Watt (read) , 5.1 Watt (write) , 55 mW (idle) , 5 mW (L1.2 mode) |
Software & System Requirements | |
Software Included | Samsung Magician Software |
Miscellaneous | |
Compliant Standards | VCCI, FCC, EAC, cRUus, IEEE 1667, UKCA |
Package Details | Box |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years / 1200 TBW |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 70 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 85 °C |
Humidity Range Operating | 5 - 95% (non-condensing) |
Shock Tolerance (non-operating) | 1500 g @ 0.5 ms |
Vibration Tolerance (non-operating) | 20 g @ 20-2000 Hz |
