We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Entertainment is given a new lease of life with this Samsung DU7100 TV. Even the blandest of scenes are given a makeover with PurColour which boosts colours while keeping them looking natural. The Crystal Processor 4K is the brain of the TV. It's hard at work in the background boosting the picture and sound of everything you watch in real-time. Sound is more realistic too thanks to Object Tracking Sound Lite – the TV speakers follow the on-screen action.
Product Description | Samsung UE75DU7100K DU7100 Series - 75" LED-backlit LCD TV - Crystal UHD - 4K | Product Type | LED-backlit LCD TV - Crystal UHD - Smart TV | Diagonal Class | 75" | Colour | Black | Platform | Tizen OS | Resolution | 3840 x 2160 | Display Format | 4K UHD (2160p) | HDR Format | HDR10+ | Frame Rate & Enhancement Technology | 50 Hz Refresh Rate, Variable Refresh Rate (VRR), Motion Xcelerator | Video Interface | HDMI | HDMI Ports Qty | 3 ports | Connectivity | Wi-Fi, LAN, Bluetooth | LCD Backlight Technology | LED backlight UHD dimming | Image Aspect Ratio | 16:9 | TV Tuner | 1x analogue, 1x digital | Digital TV Tuner | DVB-C, DVB-T2 | Internet Streaming Services | Samsung TV PLUS, HbbTV 2.0.3 | Picture Enhancements | Mega Contrast, contrast enhancer, PurColor, 4K Upscaling | Speaker System | 2 channel | Platform | SmartThings | Intelligent Assistant | Google Assistant, Alexa, Bixby (not available for some languages and countries) | USB | Yes | Included Accessories | Samsung TM2240A remote control, Samsung TM1240A remote control | Voltage | AC 220-240 V (50/60 Hz) | Energy Class | Class G | Power Consumption Operational | 139 Watt | Power Consumption Stand by | 0.5 Watt | Energy Consumption per Year | 193 kWh | Dimensions (WxDxH) - without stand | 167.75 cm x 6.11 cm x 96.24 cm | Weight | 25.3 kg | Manufacturer Warranty | 2-year warranty |
General | |
Energy Class (HDR) | Class G |
Power Consumption (Max) | 175 Watt |
Power Consumption SDR (On mode) | 139 kWh/1000h |
Power Consumption HDR (On mode) | 178 kWh/1000h |
Series | DU7100 Series |
Model Year | 2024 |
HDR Capable | Yes |
Video Processor | Crystal 4K |
TV Tuner Presence | Yes |
Sensors | Eco Sensor |
Modes | Auto Game Mode, Auto Low Latency Mode (ALLM), Filmmaker Mode, HGIG Mode, AI Energy Mode |
Design | 3 Bezel-less Design, Slim look |
Dimensions | Without stand |
Width | 167.75 cm |
Depth | 6.11 cm |
Height | 96.24 cm |
Weight | 25.3 kg |
Enclosure Colour | Black |
Display | |
Display Menu Language | Multilingual |
Features | Embeded POP, Wireless TV On, Apple AirPlay support, Samsung Health, Gaming Hub, Nifty Gateway, Workspace, USB webcam support, Samsung Daily+, Samsung Knox Security |
Stands & Mounts | |
Stand | Included |
Stand Design | Tabletop |
Stand Colour | Black |
Stand Features | Height adjustable, width adjustable, flat feet |
Flat Panel Mount Interface | 400 x 400 mm |
VESA Compatibility | Yes |
TV Tuner | |
Conditional Access | Common Interface Plus (CI+) slot |
Digital TV Tuner | |
HDTV Tuner | Yes |
Digital TV Service | HbbTV |
Video Features | |
Teletext | Yes |
Electronic Programme Guide | Digital EPG |
Media Player | |
USB Port | Yes |
USB Ports Qty | 1 |
Remote Control | |
Type | Remote control |
Remote Control Model | Samsung TM2240A |
Features | Additional remote control included |
Audio System | |
Output Power / Total | 20 Watt |
Features | Audio Return Channel (ARC), Enhanced Audio Return Channel (eARC), Audio Pre-selection Descriptor, Adaptive Sound, Q-Symphony, Object Tracking Sound Lite |
Network & Internet Multimedia | |
Functionality | WEB browsing, Internet video playback |
LAN Protocol | Ethernet |
Wi-Fi Protocol | 802.11ac |
Bluetooth Version | Bluetooth 5.2 |
Connect & Share | Screen Mirroring, Smart Hub, Sound Mirroring, IP Control |
Supported Consumer Electronics Control (CEC) | Anynet Plus |
Connections | |
Connector Type | 3 x HDMI , USB , LAN |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Communications Technology | Thread, Zigbee |
Miscellaneous | |
Included Accessories | Samsung TM1240A remote control |
Compliant Standards | CEC, HGiG |
Power | |
Power Device | Power supply |
Input Voltage | AC 220-240 V (50/60 Hz) |
Auto On/Off | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Dimensions & Weight Details | |
Dimensions & Weight Details | Panel without stand - 167.75 cm x 6.11 cm x 96.24 cm x 25.3 kg , Panel with stand - 167.75 cm x 32.5 cm x 100.63 cm x 26 kg , Stand - 125.36 cm x 32.5 cm , Stand (minimum) - 34.66 cm x 32.5 cm |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 183.2 cm |
Depth (Shipping) | 18.6 cm |
Height (Shipping) | 111 cm |
Weight (Shipping) | 34.5 kg |
