Product Description | Samsung T9 MU-PG4T0B - SSD - 4 TB - USB 3.2 Gen 2x2 | Type | Solid state drive - external (portable) | Capacity | 4 TB | Hardware Encryption | Yes | Encryption Algorithm | 256-bit AES | Interface | USB 3.2 Gen 2x2 - USB-C | Data Transfer Rate | 20 Gbps (USB 3.2 Gen 2x2) | Features | Password authentication, up to 3m to concrete drop protection | Power Source | USB bus | Enclosure Colour | Black | Dimensions (WxDxH) | 60 mm x 88 mm x 14 mm | Weight | 122 g | Localisation | Europe | Manufacturer Warranty | 5-year warranty |
General | |
Device Type | Solid state drive - external (portable) |
Capacity | 4 TB |
Interface | USB 3.2 Gen 2x2 |
Width | 60 mm |
Depth | 88 mm |
Height | 14 mm |
Weight | 122 g |
Performance | |
Interface Transfer Rate | 20 Gbps (USB 3.2 Gen 2x2) |
Max Data Transfer Rate | 2000 MB/s |
Internal Data Rate | 2000 MBps (read) / 1950 MBps (write) |
Expansion & Connectivity | |
Interfaces | 1 x USB 3.2 Gen 2x2 - 24 pin USB-C |
Power | |
Software & System Requirements | |
OS Required | Apple MacOS, Android, Windows |
Miscellaneous | |
Cables Included | USB-C cable , USB-C to USB-A cable |
Compliant Standards | UL, TUV, VCCI, BSMI, CB, IC, FCC, KC, RoHS2, EAC, RCM, BIS, UASP (USB Attached SCSI Protocol), UKCA |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 60 °C |
Min Storage Temperature | -40 °C |
Max Storage Temperature | 85 °C |
