Samsung 49" K5500 5 Series Flat FHD Smart TV
Product Description | Samsung UE49K5500AK 5 Series - 49" LED-backlit LCD TV - Full HD | Product Type | LED-backlit LCD TV - Smart TV | Diagonal Class | 49" | Colour | Dark titan | Platform | Tizen OS | Resolution | 1920 x 1080 | Display Format | 1080p | Frame Rate & Enhancement Technology | 400 Picture Quality Index, 50 Motion Rate | Video Interface | Component, composite, HDMI | HDMI Ports Qty | 3 ports | Connectivity | Wi-Fi, LAN, Bluetooth | LCD Backlight Technology | LED backlight Micro Dimming Pro | Image Aspect Ratio | 16:9 | TV Tuner | 1x analogue, 1x digital | Digital TV Tuner | DVB-C, DVB-T2 | Internet Streaming Services | Smart Hub | Multi-channel Preview | Picture-in-picture (PIP) | Speaker System | 2 speakers | USB | 2 ports | Included Accessories | Samsung TM1240A remote control, batteries | Voltage | AC 230V (50/60 Hz) | Energy Class | Class A+ | Power Consumption Operational | 100 Watt | Power Consumption (On mode) | 64 W | Power Consumption Stand by | 0.3 Watt | Energy Consumption per Year | 89 kWh | Dimensions (WxDxH) - without stand | 110.58 cm x 5.51 cm x 64.5 cm | Weight | 13 kg |
General | |
Series | 5 Series |
Video Processor | Quad-Core |
TV Tuner Presence | Yes |
Extended PVR | Yes |
Sensors | Eco Sensor |
Modes | Game mode, Film Mode |
Design | Very Narrow Bezel Design (VNB) |
Dimensions | Without stand |
Width | 110.58 cm |
Depth | 5.51 cm |
Height | 64.5 cm |
Weight | 13 kg |
Enclosure Colour | Dark titan |
Display | |
Features | Contrast enhancer, time-shift, HyperReal Engine, Wide Color Enhancer Plus, USB Cloning, Digital Clean View, E-Manual, Instant On, Embeded POP, Ultra Clean View |
Stands & Mounts | |
Stand | Included |
Stand Design | Tabletop |
Flat Panel Mount Interface | Yes |
TV Tuner | |
Conditional Access | Common Interface Plus (CI+) slot |
Digital TV Tuner | |
HDTV Tuner | Yes |
Digital TV Service | MHEG |
Video Features | |
Electronic Programme Guide | Digital EPG |
Media Player | |
USB Port | Yes |
USB Ports Qty | 2 |
Remote Control | |
Type | Remote control |
Remote Control Model | Samsung TM1240A |
Audio System | |
Digital Audio Format | DTS digital output, Dolby Digital Plus output |
Output Power / Total | 20 Watt |
Features | Down-firing Speaker, Audio Return Channel (ARC), Bass Reflex Speaker System, Wallmount Sound Mode, TV Soundconnect |
Speakers | 2 x main channel speaker - 10 Watt |
Network & Internet Multimedia | |
Functionality | Digital audio playback, digital photo playback, digital video playback, WEB browsing, Internet video playback |
LAN Protocol | Ethernet |
Connect & Share | Wi-Fi Direct, Screen Mirroring, USB Human Interface Device (HID), Samsung Smart View, ConnectShare |
Supported Consumer Electronics Control (CEC) | Anynet Plus, Multiroom Link |
DLNA | Yes |
Connections | |
Connector Type | 3 x HDMI , 2 x USB 2.0 , Composite video / component video input , Audio line-in , LAN , Digital audio output (optical) |
Miscellaneous | |
Included Accessories | Batteries |
Cables Included | Video cable |
Compliant Standards | CEC |
Power | |
Power Device | Power supply |
Input Voltage | AC 230V (50/60 Hz) |
Dimensions & Weight Details | |
Dimensions & Weight Details | Panel without stand - 110.58 cm x 5.51 cm x 64.5 cm x 13 kg , Panel with stand - 110.58 cm x 29.38 cm x 71.02 cm x 14.6 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 125.5 cm |
Depth (Shipping) | 13 cm |
Height (Shipping) | 77.3 cm |
Weight (Shipping) | 18.7 kg |
