With the Samsung F4500 Series 4 Plasma TV, superior viewing is a reality for everyone. Thanks to Clean View technology, digital noise is filtered out to give you an enhanced picture. Meanwhile, the new filter and panel structure stops layered images, dual images and blurring, as well as giving clear images from a wide range of viewpoints. Using advanced subfield motion technology, your F4500 also delivers smoother motion - even for fast-moving images. And, with ConnectShare Movie, you can access all your content on USB storage.
Filtering noise for added TV viewing pleasure
Experience crystal-clear TV viewing with Samsung's Clean View. When Clean View's auto noise-removal technology is applied, it removes digital noise that is seen on the screen, enhancing the picture quality. Sit back, relax and watch TV with the best clarity.
Clear Image Panel
The Samsung Plasma+1 TV uses a new filter and panel structure to eliminate layered images and produce clear images from almost every angle. This also eliminates the production of dual images and blurring typically found with glass.
Bringing a full multimedia experience into your living room
With High Definition Multimedia Interface (HDMI) inputs, the Samsung TV will transform your living room into a multimedia entertainment centre. HDMI provides high-speed transmission of high definition digital data from multiple devices straight into your TV.
Smoother images for greater clarity
Using the latest in subfield motion technology, Samsung Plasma TV flashes a single image up to 600 times a second. The result is smoother images with unprecedented picture quality, no matter how fast the images are moving.
Watch movies from your USB
With ConnectShare Movie, simply plug your USB memory drive or HDD into the TV and instantaneously enjoy movies, photos or music. Now, you can experience a wide variety of content in the comfort of your living room on your TV.
Product Description | Samsung PS43F4500 4 Series - 43" plasma TV | Product Type | Plasma TV | Diagonal Class | 43" | Colour | Black | Resolution | 1024 x 768 | Frame Rate & Enhancement Technology | 600Hz Subfield Motion | Video Interface | Component, composite, HDMI | HDMI Ports Qty | 2 ports | HDCP Compatible | Yes | Digital TV Tuner | DVB-C, DVB-T | Multi-channel Preview | Picture-in-picture (PIP) | Speaker System | 2 speakers | Sound Effects | DTS Studio Sound, DTS Premium Audio 5.1 | USB | Yes | Included Accessories | Samsung TM1240 remote control | Voltage | AC 230V (50/60 Hz) | Energy Class | Class B | Power Consumption Stand by | 0.3 Watt | Dimensions (WxDxH) - with stand | 100.97 cm x 23.5 cm x 69.88 cm | Weight | 15 kg | Manufacturer Warranty | 1-year warranty |
General | |
Series | 4 Series |
TV Tuner Presence | Yes |
Sensors | Eco Sensor |
Modes | Game mode |
Timer Functions | Sleep, wake |
Protection | Screen burn protection |
Dimensions | With stand |
Width | 100.97 cm |
Depth | 23.5 cm |
Height | 69.88 cm |
Weight | 15 kg |
Enclosure Colour | Black |
Display | |
Features | Cinema Smooth Technology, HyperReal Engine, Wide Color Enhancer Plus, Online Instruction Manual, Clear Image Panel, Black Optimizer, Digital Clean View |
Stands & Mounts | |
Stand | Included |
Stand Design | Tabletop |
Flat Panel Mount Interface | 400 x 400 mm |
TV Tuner | |
Conditional Access | Common Interface Plus (CI+) slot |
Digital TV Tuner | |
Video Features | |
Teletext | Yes |
Electronic Programme Guide | Digital EPG |
Media Player | |
USB Port | Yes |
USB Ports Qty | 1 |
Remote Control | |
Type | Remote control |
Remote Control Model | Samsung TM1240 |
Audio System | |
Digital Audio Format | DTS digital output, Dolby Digital Plus output, Dolby Pulse output |
Surround Mode | Yes |
Output Power / Total | 20 Watt |
Features | Down-firing Speaker, Auto Volume Leveller (AVL) |
Speakers | 2 x main channel speaker - 10 Watt |
Driver Details | Main channel speaker: 1 x full-range driver |
Network & Internet Multimedia | |
Connect & Share | ConnectShare Movie |
Connections | |
Connector Type | Composite video / component video input , Audio line-in , Digital audio output (optical) , 2 x HDMI input , USB |
Power | |
Power Device | Power supply |
Input Voltage | AC 230V (50/60 Hz) |
Auto On/Off | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts and labour - 1 year - on-site |
Dimensions & Weight Details | |
Dimensions & Weight Details | Panel without stand - 100.97 cm x 5.57 cm x 61.75 cm x 13.6 kg , Panel with stand - 100.97 cm x 23.5 cm x 69.88 cm x 15 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 111 cm |
Depth (Shipping) | 27 cm |
Height (Shipping) | 73.2 cm |
Weight (Shipping) | 19 kg |
