ITEM | QTY | PRICE |
Fitbit Aria Air - White
3 | £119.97 |
We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Your content gets the VIP treatment with this Samsung Q60 TV. Quantum Dots transform light into lifelike, accurate colour for natural looking scenes. The sky is brighter, the grass is greener, and the details are clearer. It's even been given the thumbs up by Pantone (and they know a thing or two about colour). The Crystal 4K Processor is the brain of the TV. It's hard at work in the background boosting the picture and sound of everything you watch in real-time. And with Quantum HDR, you can enjoy natural details and depth, even in the darkest of scenes. You'll have no problem seeing what's lurking in the shadows.
Product Description | Samsung QE43Q60DAU Q60D Series - 43" LED-backlit LCD TV - QLED - 4K | Product Type | LED-backlit LCD TV - QLED - Smart TV | Diagonal Class | 43" | Colour | Titan grey | Platform | Tizen OS | Resolution | 3840 x 2160 | Display Format | 4K UHD (2160p) | HDR Format | HDR10+ | HDR Technology | Quantum HDR, HDR10+ Adaptive | Frame Rate & Enhancement Technology | 50 Hz Refresh Rate, Motion Xcelerator | Video Interface | HDMI | HDMI Ports Qty | 3 ports | Connectivity | Wi-Fi, LAN, Bluetooth | LCD Backlight Technology | Quantum Dot technology, Dual LED Supreme UHD dimming | Image Aspect Ratio | 16:9 | TV Tuner | 1x analogue, 1x digital | Digital TV Tuner | DVB-C, DVB-S2, DVB-T2 | Internet Streaming Services | Samsung TV PLUS, HbbTV 2.0.3 | Picture Enhancements | Contrast enhancer, 4K Upscaling, 100% Color Volume | Speaker System | 2 channel | Platform | SmartThings | Intelligent Assistant | Google Assistant, Bixby, Alexa (not available for some languages and countries) | USB | 2 ports | Included Accessories | Samsung TM2360E remote control, Samsung TM1240A remote control | Voltage | AC 220-240 V (50/60 Hz) | Energy Class | Class F | Power Consumption Operational | 50 Watt | Power Consumption Stand by | 0.5 Watt | Energy Consumption per Year | 69 kWh | Dimensions (WxDxH) - without stand | 96.55 cm x 2.57 cm x 55.94 cm | Weight | 8.4 kg | Manufacturer Warranty | 2-year warranty |
General | |
Energy Class (HDR) | Class G |
Power Consumption (Max) | 125 Watt |
Power Consumption SDR (On mode) | 50 kWh/1000h |
Power Consumption HDR (On mode) | 101 kWh/1000h |
Series | Q60D Series |
Model Year | 2024 |
HDR Capable | Yes |
Video Processor | Quantum 4K Lite |
TV Tuner Presence | Yes |
Extended PVR | Yes |
Sensors | Eco Sensor |
Modes | Auto Game Mode, Ambient Mode, Game Motion Plus, Auto Low Latency Mode (ALLM), Filmmaker Mode, HGIG Mode, AI Energy Mode |
Design | 3 Bezel-less Design, Slim look, AirSlim design |
Dimensions | Without stand |
Width | 96.55 cm |
Depth | 2.57 cm |
Height | 55.94 cm |
Weight | 8.4 kg |
Enclosure Colour | Titan grey |
Display | |
LCD Backlight Technology | Quantum Dot technology, Dual LED - Supreme UHD dimming |
Display Menu Language | Multilingual |
Features | Smart Calibration, Wireless TV On, Apple AirPlay support, Samsung Health, Super Ultra Wide Game View, Game bar, Mobile camera support, Mini Map Zoom, Gaming Hub, Nifty Gateway, Workspace, Light-Sync, Samsung Daily+, Samsung Knox Security |
Stands & Mounts | |
Stand | Included |
Stand Design | Tabletop |
Stand Colour | Titan grey |
Stand Features | Height adjustable, New Simple Stand |
Flat Panel Mount Interface | 200 x 200 mm |
VESA Compatibility | Yes |
TV Tuner | |
Conditional Access | Common Interface Plus (CI+) slot |
Digital TV Tuner | |
HDTV Tuner | Yes |
Digital TV Service | HbbTV |
Video Features | |
Teletext | Yes |
Electronic Programme Guide | Digital EPG |
Media Player | |
USB Port | Yes |
USB Ports Qty | 2 |
Remote Control | |
Type | Remote control |
Remote Control Model | Samsung TM2360E |
Features | Additional remote control included, SolarCell remote |
Audio System | |
Output Power / Total | 20 Watt |
Features | Audio Return Channel (ARC), Enhanced Audio Return Channel (eARC), Audio Pre-selection Descriptor, Adaptive Sound, Q-Symphony, Object Tracking Sound Lite |
Network & Internet Multimedia | |
Functionality | WEB browsing, Internet video playback |
LAN Protocol | Ethernet |
Wi-Fi Protocol | 802.11ac |
Bluetooth Version | Bluetooth 5.2 |
Connect & Share | Screen Mirroring, Smart Hub, Sound Mirroring, IP Control, Tap View, Multi View |
Supported Consumer Electronics Control (CEC) | Anynet Plus |
Connections | |
Connector Type | 3 x HDMI , 2 x USB , LAN , Digital audio output (optical) |
Internet of Things (IoT) | |
Internet of Things (IoT) Compatible | Yes |
Communications Technology | Thread, Zigbee |
Intelligent Assistant | Google Assistant, Bixby, Alexa built-in (not available for some languages and countries) |
Miscellaneous | |
Included Accessories | Samsung TM1240A remote control |
Compliant Standards | VDE, CEC, HGiG, Pantone Validated |
Power | |
Power Device | Power supply |
Input Voltage | AC 220-240 V (50/60 Hz) |
Auto On/Off | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Dimensions & Weight Details | |
Dimensions & Weight Details | Panel without stand - 96.55 cm x 2.57 cm x 55.94 cm x 8.4 kg , Panel with stand - 96.55 cm x 18.1 cm x 59.81 cm x 8.6 kg , Stand - 67.8 cm x 18.1 cm |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 109.3 cm |
Depth (Shipping) | 12.6 cm |
Height (Shipping) | 66.7 cm |
Weight (Shipping) | 11.6 kg |
