Marketing description is not available.
Product Description | Samsung UE40K6300AK 6 Series - 40" LED-backlit LCD TV - Full HD | Product Type | Curved LED-backlit LCD TV - Smart TV | Diagonal Class | 40" | Colour | Dark titan | Resolution | 1920 x 1080 | Display Format | 1080p | Frame Rate & Enhancement Technology | 800 Picture Quality Index | Video Interface | Component, composite, HDMI | HDMI Ports Qty | 3 ports | Connectivity | Wi-Fi, LAN, Bluetooth | LCD Backlight Technology | LED backlight Micro Dimming Pro | Image Aspect Ratio | 16:9 | Digital TV Tuner | DVB-C, DVB-T | Multi-channel Preview | Picture-in-picture (PIP) | USB | 2 ports | Included Accessories | Remote control, batteries | Voltage | AC 230V (50/60 Hz) | Energy Class | Class A | Power Consumption (On mode) | 55 W | Power Consumption Stand by | 0.3 Watt | Energy Consumption per Year | 76 kWh | Dimensions (WxDxH) - without stand | 91.65 cm x 8.91 cm x 54.06 cm | Weight | 9 kg |
General | |
Curved Screen | Yes (3000R) |
Series | 6 Series |
Video Processor | Quad-Core |
TV Tuner Presence | Yes |
Extended PVR | Yes |
Modes | Game mode, Natural Mode, Sports Mode Advanced, Cinema mode |
Design | Very Narrow Bezel Design (VNB) |
Dimensions | Without stand |
Width | 91.65 cm |
Depth | 8.91 cm |
Height | 54.06 cm |
Weight | 9 kg |
Enclosure Colour | Dark titan |
Display | |
Features | HyperReal Engine, Wide Color Enhancer Plus, USB Cloning, E-Manual, Auto Depth Enhancer, Instant On, Motion Compensation, Multiroom Compatible, Accessibility Zoom, Accessibility High contrast |
Stands & Mounts | |
Stand | Included |
Stand Design | Tabletop |
Flat Panel Mount Interface | Yes |
TV Tuner | |
Conditional Access | Common Interface Plus (CI+) slot |
Digital TV Tuner | |
HDTV Tuner | Yes |
Digital TV Service | TNT, HbbTV |
Video Features | |
Teletext | Yes |
Electronic Programme Guide | Digital EPG |
Media Player | |
USB Port | Yes |
USB Ports Qty | 2 |
Remote Control | |
Type | Remote control |
Audio System | |
Digital Audio Format | DTS digital output, Dolby Digital Plus output |
Output Power / Total | 20 Watt |
Network & Internet Multimedia | |
Functionality | Digital audio playback, digital photo playback, digital video playback, Internet video playback |
LAN Protocol | Ethernet |
Connect & Share | Wi-Fi Direct, Screen Mirroring, ConnectShare, Sound Share |
Supported Consumer Electronics Control (CEC) | Anynet Plus |
Connections | |
Connector Type | 3 x HDMI , 2 x USB 2.0 , Composite video / component video input , LAN , Digital audio output (optical) , Audio line-in |
Miscellaneous | |
Included Accessories | Batteries |
Compliant Standards | CEC |
Power | |
Power Device | Power supply |
Input Voltage | AC 230V (50/60 Hz) |
Auto On/Off | Yes |
Dimensions & Weight Details | |
Dimensions & Weight Details | Panel without stand - 91.65 cm x 8.91 cm x 54.06 cm x 9 kg , Panel with stand - 91.65 cm x 25.07 cm x 60.75 cm x 10.1 kg |
Dimensions & Weight (Shipping) | |
Width (Shipping) | 100 cm |
Depth (Shipping) | 15 cm |
Height (Shipping) | 62.5 cm |
Weight (Shipping) | 12.4 kg |
