The curvature of the screen provides a truly immersive viewing experience that lets you enjoy big, bold and stunning panoramic views while you work or play. With its design inspired by the curve of the human eye, the Samsung CF390 monitor delivers a comfortable and enjoyable viewing experience for your home or office use. It features an ultra-slim and sleek profile that makes a stylish statement while staying productive.
Product Description | Samsung C24F390FHU - CF390 Series - LED monitor - curved - Full HD (1080p) - 23.5" | Device Type | LED-backlit LCD monitor - 23.5" | Energy Class | Class G | Energy Consumption per Year | 35 kWh | Power Consumption (On mode) | 24 W | Curved Screen | Yes | Adaptive-Sync Technology | AMD FreeSync | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | Full HD (1080p) 1920 x 1080 | Pixel Pitch | 0.271 mm | Brightness | 250 cd/m² | Contrast Ratio | 3000:1 | Response Time | 4 ms | Colour Support | 16.7 million colours | Input Connectors | HDMI, VGA | Display Position Adjustments | Tilt | Colour | Shiny black | Dimensions (WxDxH) - with stand | 54.78 cm x 20.65 cm x 41.82 cm | Weight | 3.3 kg | Compliant Standards | DDC-2B, ISO 9241-307 |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 23.5" |
Curved Screen | Yes (1800R) |
Panel Type | VA |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | MagicBright, power off timer, HDCP, game mode, Mega Dynamic Contrast Ratio, Eco Saving, Magic Upscale, Flicker Free technology, Mercury free, Eye Saver Mode |
Dimensions (WxDxH) | 54.78 cm x 20.65 cm x 41.82 cm - with stand |
Weight | 3.3 kg |
Connectivity | |
Interfaces | VGA , HDMI (HDCP) , Headphones |
Mechanical | |
Miscellaneous | |
Cables Included | 1 x HDMI cable |
Power | |
Power Consumption SDR (On mode) | 24 kWh/1000h |
Power Consumption Stand by | 0.3 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Software / System Requirements | |
OS Required | Apple MacOS, Windows 10 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 54.78 cm - depth: 20.65 cm - height: 41.82 cm - weight: 3.3 kg , Without stand - width: 54.78 cm - depth: 8.76 cm - height: 32.63 cm |
