A flexible, weather-resistant outdoor security camera that puts pro-grade security exactly where you need it. Stick it up anywhere you want to see and hear more with advanced features like 3D Motion Detection, HDR video, and Audio+.
Plug-In power means non-stop peace of mind. Place Stick Up Cam Pro on a flat surface for flexibility, or put it on the wall or ceiling with the included camera mount for a more permanent solution.
Product Description | Ring Stick Up Cam Pro Plug-In - network surveillance camera | Device Type | Network surveillance camera - fixed - outdoor - weather resistant | Audio | Yes: two-way audio capability | Camera Mount Type | Wall mount, ceiling mount | Dimensions (WxDxH) | 7 cm x 7 cm x 15.39 cm | Colour | Black | Connectivity Technology | Wireless | Camera | Colour - Day&Night | Max Resolution | 1920 x 1080 | Motion Detection | Yes | Video Modes | 1080p | Interfaces | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n | Cables Included | 1 - USB-C charge cable - external - 6 m | Features | Live View Control, Smartphone Monitoring, High Dynamic Range (HDR), Colour Night Vision, 3D Motion Detection, Bird's Eye View, customisable motion zones, built-in siren (85 dB), Bird's Eye Zones | Manufacturer Warranty | 1-year warranty | Environmental Parameters (operating) | -20 °C - 48.5 °C |
General | |
Device Type | Network surveillance camera |
Audio Support | Yes: two-way audio capability |
Width | 7 cm |
Depth | 7 cm |
Height | 15.39 cm |
Camera | |
Type | Colour - Day&Night - fixed - outdoor - weather resistant |
Max Digital Video Resolution | 1920 x 1080 |
Digital Video Capture Resolution | 1920 x 1080 |
Lens Construction | |
Horizontal Field of View (degree) | 139 |
Vertical Field of View (degree) | 80 |
Diagonal Field of View (degree) | 155 |
Interfaces | |
Network Interface | IEEE 802.11b, IEEE 802.11g, IEEE 802.11n |
Expansion / Connectivity | |
Ports | USB-C (power only) - 24-pin USB-C |
Miscellaneous | |
Included Accessories | Mounting kit, security sticker, power adapter |
Cables Included | 1 x USB-C charge cable - external - 6 m |
Colour | Black |
Power | |
Power Device | Power adapter - external |
Software / System Requirements | |
Software Included | Ring Protect (30 days trial) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 48.5 °C |
