Stick Up Cam Plugin
£54.99
White
Get non-stop power for non-stop peace of mind with a motion-activated camera that goes anywhere, inside or out. It installs in minutes and plugs into standard UK power sockets, so you’ll never have to worry about charging a battery. Place it on a flat surface for flexibility or on a wall for a secure mount. Wherever you are, Stick Up Cam Plug-In lets you check in on your home at any time.
Goes everywhere. Sees everything.
With countless placement options and customisable motion settings, find the perfect setup for you and your home.
Cover Every Corner
Up high. Mount it on the side of your garage, or to a wall in the living room. Make sure the pets don’t get into too much trouble, or check to see if there’s anyone snooping in your garden.
Down low. It also goes on a flat surface like a coffee table inside, or your patio outside. Watch the pets play at home while you’re at work, or just make sure there’s no one sneaking down your driveway.
Complete control from the Ring app.
The Ring app unlocks all the features your devices have to offer so you can protect your home, your way.
Product Description | Ring Stick Up Cam Plug-In - 3rd Generation - network surveillance camera | Device Type | Network surveillance camera - fixed - outdoor, indoor - weatherproof | Audio | Yes: two-way audio capability | Camera Mount Type | Wall mount, ceiling mount | Dimensions (WxDxH) | 6 cm x 6 cm x 9.7 cm | Colour | White | Connectivity Technology | Wired, wireless | Camera | Colour - Day&Night | Motion Detection | Yes | Video Modes | 1080p | Interfaces | Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11a | Cables Included | 1 - micro-USB cable - external | Voltage | USB / AC Power | Features | Audio Noise Reduction | Manufacturer Warranty | 1-year warranty | Environmental Parameters (operating) | -20.5 °C - 48.5 °C |
General | |
Device Type | Network surveillance camera |
Audio Support | Yes: two-way audio capability |
Width | 6 cm |
Depth | 6 cm |
Height | 9.7 cm |
Localisation | United Kingdom |
Camera | |
Type | Colour - Day&Night - fixed - outdoor, indoor - weatherproof |
Lens Construction | |
Horizontal Field of View (degree) | 110 |
Vertical Field of View (degree) | 57 |
Diagonal Field of View (degree) | 130 |
Interfaces | |
Network Interface | Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, IEEE 802.11a |
Expansion / Connectivity | |
Ports | LAN/power |
Miscellaneous | |
Included Accessories | Base cover, 2 power adapters, security sticker, base pad |
Cables Included | 1 x micro-USB cable - external |
Colour | White |
Power | |
Power Requirements | USB / AC |
Manufacturer Warranty | |
Service & Support | Limited warranty - parts - 1 year |
Environmental Parameters | |
Min Operating Temperature | -20.5 °C |
Max Operating Temperature | 48.5 °C |
