FEATURES
Robust Aluminum Unibody
The Razer Manticor is constructed from a single sheet of aircraft-grade aluminum, stamped flatter and smoother for an unhindered glide. At the same time, the molecular rebonding from the machining process creates a highly rigid structure for maximum durability. It is then sand-blasted for a texture that further aids tracking precision and provides a great feel under your hand as you swipe.
Optimized Tracking Surface
The Razer Manticor's entire surface has a lab-developed microscopic texture that delivers the most consistently accurate sensor readings. There are no in-game jitters or interrupted tracking problems when using this mat.
Its finish was specifically chosen during extensive testing as the best for sensor reflectivity. What you get is the rapid responsiveness to meet challenges head-on and effortlessly land every headshot.
Thinner, Wider Profile
The Razer Manticor has been cut thinner for a slimmer profile that almost melds to your desk. This ensures a continuous swiping experience even if your mouse were to travel off the generously expansive surface of your mouse mat. It is also ergonomically more comfortable, minimizing wrist strain so you can keep winning in games for longer.
TECH SPECS
Product Description | Razer Manticor Elite Gaming Mouse Mat - mouse pad | Product Type | Mouse pad | Product Material | Aluminium, rubber | Dimensions (WxDxH) | 25.5 cm x 35.5 cm | Weight | 373 g | Manufacturer Warranty | 6 months warranty |
General | |
Width | 25.5 cm |
Depth | 35.5 cm |
Thickness | 0.22 cm |
Weight | 373 g |
Miscellaneous | |
Features | Non-slip, Ultra-Smooth Sandblasted Surface |
Manufacturer Warranty | |
Service & Support | Limited warranty - 6 months |
