Razer Manticor Elite Aluminium Gaming Mouse Mat
free standard delivery
Key features
  • Ultra-smooth, sandblasted surface
  • Robust aluminum uniKeySellingPoints
  • Thinner, wider profile
  • Non-slip rubber base
Product codes
chevron icon
chevron icon
FEATURES
Robust Aluminum Unibody
The Razer Manticor is constructed from a single sheet of aircraft-grade aluminum, stamped flatter and smoother for an unhindered glide. At the same time, the molecular rebonding from the machining process creates a highly rigid structure for maximum durability. It is then sand-blasted for a texture that further aids tracking precision and provides a great feel under your hand as you swipe.
Optimized Tracking Surface
The Razer Manticor's entire surface has a lab-developed microscopic texture that delivers the most consistently accurate sensor readings. There are no in-game jitters or interrupted tracking problems when using this mat.
Its finish was specifically chosen during extensive testing as the best for sensor reflectivity. What you get is the rapid responsiveness to meet challenges head-on and effortlessly land every headshot.
Thinner, Wider Profile
The Razer Manticor has been cut thinner for a slimmer profile that almost melds to your desk. This ensures a continuous swiping experience even if your mouse were to travel off the generously expansive surface of your mouse mat. It is also ergonomically more comfortable, minimizing wrist strain so you can keep winning in games for longer.
TECH SPECS
  • Robust aluminum unibody
  • Product dimensions:
    Width: 255 mm / 10.04" Length: 355 mm / 13.98" Height: 2.2 mm / 0.09"
  • Approximate Weight: 373 g / 0.82lbs
chevron icon
Product Description Razer Manticor Elite Gaming Mouse Mat - mouse pad
Product Type Mouse pad
Product Material Aluminium, rubber
Dimensions (WxDxH) 25.5 cm x 35.5 cm
Weight 373 g
Manufacturer Warranty 6 months warranty
Need it in a hurry?
Over 10,000 products
UK customer service
Over 25 years of experience
