ILLUMINATE YOUR SOUND
Light up your setup with an audio experience like never seen before. Meet the Razer Leviathan V2 X—a compact, USB Type C powered PC gaming soundbar that makes a worthy addition to your battlestation for all your games, movies, and music.
PC SOUNDBAR WITH FULL-RANGE DRIVERS
Dynamic, High-fidelity Audio, Armed with two full-range drivers and two passive radiators for bold clarity and resonating depth, the Razer Leviathan V2 X delivers a riveting audio experience across all your entertainment.
COMPACT DESKTOP FORM FACTOR
Spacious Sound, Minimal Footprint, At just 400 mm in length, the most compact soundbar in our Leviathan V2 range fits perfectly beneath your monitor for a clutter-free desktop—delivering a vibrant, wide soundstage.
USB TYPE C POWER AND AUDIO DELIVERY
Optimum Power With Hassle-free Connectivity, Powered by a single USB Type C cable, the Razer Leviathan V2 X draws power more efficiently* to deliver dynamic audio with a volume output of 90dB at 1 m and enables fuss-free connectivity for an easy setup
BLUETOOTH 5.0
Seamless PC And Mobile Connection, Enjoy smooth, stutter-free sound with a low-latency Bluetooth connection, as you switch seamlessly between your PC and your preferred mobile device that’s conveniently paired via the Razer Audio App
POWERED BY RAZER CHROMA™ RGB
Greater Customization And Immersion, With 14 lighting zones, countless patterns, dynamic in-game lighting effects—experience full RGB customization and deeper immersion with the world’s largest lighting ecosystem for gaming devices.
RAZER AUDIO APP AND RAZER SYNAPSE
A Truly Personalized Experience, From customizing RGB lighting to toggling between audio devices, tweak the soundbar to best suit your entertainment needs with software designed to give you more control at greater convenience.
Product Description | Razer Leviathan V2 X - sound bar - for PC - wireless | Product Type | Sound bar - for PC | Speaker Type | Active | Frequency Response | 85 - 20000 Hz | Amplifier | Integrated | Interfaces | Bluetooth | Speaker Details | Sound bar - stereo x 2 - active |
General | |
Light | Multicolour LED light |
Speaker System | |
Max Output Level (Max SPL) | 90 dB |
Interfaces | Bluetooth 5.0 |
Controls | Power on/off, volume |
App-Controlled | Yes |
Interface Type | USB |
Speaker System Details | |
Driver Details | Sound bar: 2 x full-range driver - 2" x 4" , Sound bar: 2 x Passive Radiator - 2" x 4.1" |
Connections | |
Connector Type | USB (USB Type-C) |
Miscellaneous | |
Included Accessories | AC power adaptor |
Power | |
Power Source | AC power adapter |
Dimensions & Weight | |
Dimensions (WxDxH) / Weight Details | / 845 g |
Customer return - item has been opened but is in excellent condition
Ref: H8QF 048611 |
Accessories | |
Packaging | |
Functional | |
Software | |
Manuals | |
£61.41
