The TVS-671 is a powerful NAS storage solution designed for I/O-intensive tasks, mission-critical business applications and fast-growing data storage needs. Incorporating reliability and security, the TVS-671 delivers high performance with persistent throughput and provides a comprehensive storage solution for SMBs to build a reliable private cloud.
Product Description | QNAP TVS-671 - NAS server - 12 TB | Device Type | NAS server | Host Connectivity | Gigabit Ethernet | Total Storage Capacity | 12 TB | Installed Devices / Modules Qty | 4 (installed) / 6 (max) | Dimensions (WxDxH) | 25.7 cm x 23.5 cm x 17.5 cm | Weight | ) | Processor | 1 x Intel Core i5 4590S 3 GHz (Quad-Core) | Storage Controller | RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare | Hard Drive | 4 x 3 TB SATA 6Gb/s | Networking | 10Mb LAN, 100Mb LAN, GigE | RAM | 8 GB | Power | AC 120/230 V (50/60 Hz) | Storage Operating System | QNAP QTS 4.1 | System Requirements | UNIX, Linux, Apple MacOS X, Microsoft Windows XP or later, Microsoft Windows Server 2003 or later |
General | |
Width | 25.7 cm |
Depth | 23.5 cm |
Height | 17.5 cm |
Weight | ) |
Built-in Devices | Status LCD, led panel |
Processor / Memory | |
Processors Installed | 1 x Intel Core i5 4590S 3 GHz |
Number of Cores | Quad-Core |
Max Supported Qty | 1 |
RAM | 8 GB (installed) / 16 GB (supported) - DDR3 |
Flash Memory Installed | 512 MB |
Storage Controller | |
Type | RAID |
Interface Type | SATA 6Gb/s |
RAID Level | RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare |
Hard Drive | |
Type | HDD - hot-swap - 3.5" |
Capacity | 4 x 3 TB |
Spindle Speed | 7200 rpm |
Networking | |
Data Link Protocol | 10Mb LAN, 100Mb LAN, GigE |
Network / Transport Protocol | TCP/IP, PPTP, UDP/IP, NTP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS |
Remote Management Protocol | SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH |
Network Services Compatibility | Microsoft Active Directory (AD), Apple Bonjour Protocol, File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV) |
Features | VPN support, trunking, LDAP support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, firmware upgradable, proxy server, backup server, file sharing, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, UPnP Media Server, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, NTP server, DHCP client, e-mail notification, cloud backup, VPN Server, SFTP client, Apple AirPlay, anti-virus protection |
Encryption Algorithm | SSL, TLS, FIPS 140-2, 256-bit AES |
Compliant Standards | UPnP |
Expansion / Connectivity | |
Expansion Bays | 6 (total) / 2 (free) x hot-swap - 2.5" / 3.5" |
Expansion Slots | 1 (total) / 1 (free) x PCI Express 3.0 x8 , 1 (total) / 1 (free) x PCI Express 2.0 x4 , 2 (total) / 0 (free) x SO-DIMM 204-pin |
Interfaces | 4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 3 x USB 3.0 - Type A , 1 x HDMI output |
Miscellaneous | |
Cables Included | 4 x network cable |
Features | Security lock slot (cable lock sold separately), audible alarm, lockable, built-in 2 cooling fans |
Security Slot Type | Kensington security slot |
Compliant Standards | FIPS 140-2 |
Included Accessories | 2 x front panel key |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Provided | 250 Watt |
Software / System Requirements | |
Software Included | QNAP Virtualization Station |
OS Required | UNIX, Linux, Apple MacOS X, Microsoft Windows XP or later, Microsoft Windows Server 2003 or later |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 5 - 95% (non-condensing) |
Sound Emission | 21 dB |
