The TS-853BU is a 2U rackmount NAS that easily fits into a standard 19-inch rack, providing an ideal storage solution in the server room for small and medium businesses. The TS-853BU comes with a PCIe slot for boosting potential applications: the QNAP QM2 expansion card can be installed to add an M.2 SSD cache/10GbE connectivity, a compatible wireless card can be installed to use the TS-853BU as a wireless access point, and a USB 3.1 10Gbps card can be added for easier backup to/from multiple external storage. The TS-853BU also provides a wide range of value-added features: 4K video playback and real-time transcoding; deployment of virtual environments through Virtualization Station and Container Station; centralized management of remote Windows®, Linux® and IPMI-compatible devices with QRM+; and web automation services with IFTTT Agent.
Product Description | QNAP TS-853BU - NAS server | Device Type | NAS server | Host Connectivity | Gigabit Ethernet | Enclosure Type | Rack-mountable - 2U | Installed Devices / Modules Qty | 0 (installed) / 8 (max) | Dimensions (WxDxH) | 48.2 cm x 53.4 cm x 8.9 cm | Weight | 11.02 kg () | Processor | 1 x Intel J3455 1.5 GHz (Quad-Core) | Storage Controller | RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, 5 hot spare, 6 hot spare, 10 hot spare | Networking | 10Mb LAN, 100Mb LAN, 1GbE | RAM | 8 GB | Storage Operating System | QNAP QTS 4.3 | System Requirements | UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.7 or later, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10 |
General | |
Total Storage Capacity | 0 GB |
Width | 48.2 cm |
Depth | 53.4 cm |
Height | 8.9 cm |
Processor / Memory | |
Processors Installed | 1 x Intel J3455 1.5 GHz |
Number of Cores | Quad-Core |
Max Supported Qty | 1 |
RAM | 8 GB (installed) / 8 GB (supported) - DDR3L |
Flash Memory Installed | 4 GB |
Storage Controller | |
Type | RAID |
Interface Type | SATA 6Gb/s |
RAID Level | RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare |
Networking | |
Data Link Protocol | 10Mb LAN, 100Mb LAN, 1GbE |
Network / Transport Protocol | TCP/IP, PPTP, UDP/IP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS |
Remote Management Protocol | SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH |
Network Services Compatibility | Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV) |
Features | VPN support, trunking, LDAP support, VLAN support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, antivirus analysis, IP address filtering, firmware upgradable, proxy server, MySQL server, web server, backup server, download client, file sharing, event log, Trivial File Transfer Protocol (TFTP) support, RADIUS support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, UPnP Media Server, Network Access Protection (NAP), bandwidth control, IPv4 support, surveillance station, teaming support, PXE support, DLNA Media Server, Apple Time Machine compatible, Link Aggregation Control Protocol (LACP), TFTP server, DHCP client, e-mail notification, cloud backup, VPN Server |
Encryption Algorithm | SSL, 256-bit AES |
Compliant Standards | IEEE 802.3ad (LACP), IEEE 802.1x, UPnP |
Expansion / Connectivity | |
Expansion Bays | 8 (total) / 8 (free) x hot-swap - 2.5" / 3.5" |
Expansion Slots | 2 (total) / 0 (free) x SO-DIMM 204-pin , 1 (total) / 1 (free) x PCI Express 2.0 x2 |
Interfaces | 4 x Ethernet 1000Base-T - RJ-45 , 4 x USB 3.0 - Type A , 1 x HDMI output |
Miscellaneous | |
Cables Included | 2 x network cable |
Features | Audible alarm, wake on LAN, built-in 2 cooling fans |
Power | |
Power Device | Internal power supply |
Installed Qty | 1 |
Power Consumption Operational | 52.1 Watt |
Power Provided | 250 Watt |
Software / System Requirements | |
OS Required | UNIX, Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.7 or later, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows 7 / 8 / 10 |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 0 - 95% |
