The powerful quad-core TS-831XU includes two 10GbE SFP+ ports to fully support 10GbE high-speed networks at a budget price with maximized ROI. The TS-831XU is a cost-effective storage solution designed for growing businesses looking for backup, restoration, private cloud, storage for virtualization, and to future-proof their IT infrastructure for 10GbE networks.
Product Description | QNAP TS-831XU - NAS server | Device Type | NAS server | Host Connectivity | Gigabit Ethernet / 10 Gigabit Ethernet | Enclosure Type | 2U | Installed Devices / Modules Qty | 0 (installed) / 8 (max) | Dimensions (WxDxH) | 48.2 cm x 53.4 cm x 8.9 cm | Weight | 10.9 kg () | Processor | 1 x Annapurna Labs Alpine AL-314 1.7 GHz (Quad-Core) | Storage Controller | RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare | Networking | 10Mb LAN, 100Mb LAN, 1GbE, 10GbE | IP Cameras Supported | 72 | RAM | 4 GB | Power | AC 120/230 V (50/60 Hz) | Storage Operating System | QNAP QTS 4.3 | System Requirements | UNIX, Linux, Apple MacOS X, Microsoft Windows 7, Windows 8, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2 |
General | |
Total Storage Capacity | 0 GB |
Width | 48.2 cm |
Depth | 53.4 cm |
Height | 8.9 cm |
Built-in Devices | Led panel |
Processor / Memory | |
Processors Installed | 1 x Annapurna Labs Alpine AL-314 1.7 GHz |
Number of Cores | Quad-Core |
Max Supported Qty | 1 |
RAM | 4 GB (installed) / 16 GB (supported) - DDR3 |
Flash Memory Installed | 512 MB |
Storage Controller | |
Type | RAID |
Interface Type | SATA 6Gb/s |
RAID Level | RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare |
Networking | |
Data Link Protocol | 10Mb LAN, 100Mb LAN, 1GbE, 10GbE |
Network / Transport Protocol | TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS |
Remote Management Protocol | SNMP, Telnet, HTTP, HTTPS, TFTP, SSH |
Network Services Compatibility | Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV), SFTP |
Features | Hardware encryption, VPN support, trunking, LDAP support, wake on LAN (WOL), Syslog support, manageable, E-mail alert, print server, IPv6 support, 256-bit encryption, proxy server, backup server, download client, file sharing, event log, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, reset button, bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, e-mail notification, cloud backup, VPN Server, SFTP client, SNMP support, Apple AirPlay, Dropbox support, Real-time Remote Replication (RTRR), Google Drive support |
Encryption Algorithm | SSL, TLS, 256-bit AES |
Compliant Standards | DLNA CERTIFIED, UPnP |
Security DVR | |
Expansion / Connectivity | |
Expansion Bays | 8 (total) / 8 (free) x hot-swap - 2.5" / 3.5" |
Expansion Slots | 2 x SO-DIMM 204-pin , 1 (total) / 1 (free) x PCI Express 2.0 x2 |
Interfaces | 2 x Ethernet 1000Base-T - RJ-45 , 4 x USB 3.0 - Type A , 2 x Ethernet 10Gb - SFP+ , 1 x management |
Miscellaneous | |
Cables Included | 2 x network cable |
Features | Security lock slot (cable lock sold separately), audible alarm, built-in 2 cooling fans, scheduled power on/off |
Power | |
Power Device | Internal power supply |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 52.78 Watt |
Power Provided | 240 Watt |
Software / System Requirements | |
OS Required | UNIX, Linux, Apple MacOS X, Microsoft Windows 7, Windows 8, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2 |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 5 - 95% (non-condensing) |
Sound Emission | 41.3 dBA |
