BT.com
Wishlist
PNY NVIDIA GeForce GTX 1080 8GB GDDR5X PCIe3.0 Graphics Card
PNY NVIDIA GeForce GTX 1080 8GB...
£608.70
£608.70
Add to wishlist
Delivery
Standard Due date unavailable
The PNY NVIDIA GeForce GTX 1080 is a quantum leap in performance. Faster than both the GeForce GTX 980 Ti and GeForce GTX TITAN X, With the power of the NVIDIA Pascal architecture, the efficiency and performance of the 16nm FinFET GPU, the blistering speed of the GDDR5X VRAM, and the craftsmanship of the fan, vapor chamber, and backplate the PNY GTX 1080 is the world's fastest and most advanced graphics card.
The PNY GTX 1080 uses the power of Pascal. NVIDIA Pascal is the world’s most advanced GPU architecture delivering truly game-changing performance, innovative technologies, and immersive, next-gen VR. With brilliant gameplay with captivating sights and sounds, it’s a whole new way to game.It features NVIDIA GameWorks technologies for smooth gameplay and cinematic experiences, as well as revolutionary 360-degree image capture-even in VR.
Under the hood, the new Pascal architecture is loaded with technologies that will make your games and experiences better, faster, and more beautiful. Previous-generation architectures have brought advances such as DSR, G-SYNC and HairWorks to life, and with Pascal we're introducing gamers to Ansel, Simultaneous Multi-Projection, VRWorks Audio, VR PhysX, and VR Touch.
PNY’s GTX 1080 is a quantum leap forward in performance and power efficiency. It is built using ultra-fast FinFET, this new, smaller chip design uses fewer Watts of power and emits less heat, enabling us to crank up the core clock speed of the GPU, which is key for increasing a graphics card's performance. Alongside the FinFET is 8GB of GDDR5X memory, a new, faster type of video card memory. This cutting-edge and blazing fast, High Bandwidth memory ensures performance won’t be bottlenecked by memory-related operations in the most demanding games.
The PNY GeForce GTX 1080 is meticulously crafted to offer superior heat dissipation using an advanced vapor chamber and premium materials, so it runs as cool as it looks. Surrounding the GeForce GTX 1080's powerful hardware is a redesigned vapor chamber and fan for cool, quiet operation; a polygonal shroud, and a backplate for the dissipation of heat from the rear of the graphics card. This premium design enables excellent overclocking and whisper-quiet operation, a trend we began with previous-generation NVIDIA GeForce GTX GPUs.
HDMI 2.0b / 3x DisplayPort 1.4 / Dual-Link DVI
PNY GeForce GTX 1080 - Founders Edition - graphics card - GF GTX 1080 - 8 GB
Dedicated Memory
8GB GDDR5X
Memory Interface
256-BIT
Memory Bandwith
320 GB / sec
GPU Cores
2560
Clocks
1 607 MHz Base/1 733 MHz Boost
System Interface
PCI Express 3.0
TDP
180 W
Thermal Solution
Single Active Fan
Display Connectors
DVI, 3x DP, HDMI
Resolution
7680 x 4320 @ 60 Hz
Power Input
1 x PCIE 8-pin
Supported SLI
NVIDIA® SLI® w/ HB Bridge Support
Sku
GF1080GTX8GEPB
EAN
3536403350765
Incl. in the box
GeForce Experience CD, Quick Start Guide, 2x6-pin to 1x8-pin PCIE adapter
Dedicated Memory
8GB GDDR5X
Memory Interface
256-BIT
Memory Bandwith
320 GB / sec
GPU Cores
2560
Clocks
System Interface
PCI Express 3.0
TDP
180 W
Thermal Solution
Single Active Fan
Display Connectors
DVI, 3x DP, HDMI
Resolution
7680 x 4320 @ 60 Hz
Power Input
1 x PCIE 8-pin
Supported SLI
Sku
GF1080GTX8GEPB
EAN
3.5364E+12
Incl. in the box
Accessories
£9.54
C2G HDMI to DisplayPort Adapter Converter
Quicklinx: 9MR6 | In Stock
£44.23
£17.40
£9.80
£22.39
£12.42
£15.15
Scroll to top
