Concentrate in comfort
With its contemporary, boomless design and active noise canceling, Voyager 8200 UC blocks out background noise so you can concentrate on your work or your call in comfort and style. Soft ear cushions, 24 hours of listening time and a 3.5 mm audio cable allow you to take calls or play music whether you're in the office, on a flight or on the go. Roam with ease at a range of up to 30 m/98 ft with a Class 1 Bluetooth device.
Immerse yourself in rich audio
Hear music and conversations with complete clarity. All tones, from high to low and everything in between, sound full and natural. Need to tune out distractions? The hi-fi stereo sound and dual-mode active noise canceling cut background noise while the boomless dual-paired microphones keep the focus on your voice.
Stay connected
Need to connect to your computer and mobile phone? No problem. By staying connected to two devices at once, you'll never miss a call. Play music or answer your phone simply by putting on the headset, and pause your media player or mute a call by taking it off. A dedicated button gives you quick access to mute, while voice prompts alert you if you're on mute when you start talking.
Customize your experience
Choose the settings that make your life easier with the Plantronics Hub app for iPhone and Android. Select language preference, feature settings, call, and mute notifications. Keep your device updated with Plantronics Hub over-the-air firmware updates.
Seamless IT management
Plantronics Manager Pro, when used with Plantronics-supported devices such as Voyager 8200 UC, is software-as-a-service that allows IT to manage headset inventory, monitor usage, and maintain devices -- all from a web browser.
Product Description | Poly Voyager 8200 UC - headphones with mic | Product Type | Headphones - Bluetooth - wireless - NFC - 3.5 mm jack | Recommended Use | Portable electronics, computer | Additional Functions | DSP | Localisation | Worldwide | Colour | Black | Headphones Form Factor | Full size | Connectivity Technology | Wireless | Wireless Technology | Bluetooth | Bluetooth Version | Bluetooth 4.1 | Sound Output Mode | Stereo | Active Noise Canceling | Yes | Microphone Noise Cancelling | Yes | Microphones Included | 4 | Controls | Mute, volume control, on/off, answer/end, next/previous track, reject call, redial | Intelligent Assistant | Siri, Cortana, Google Now | Software Certification | Certified for Microsoft Teams | Manufacturer Warranty | 2-year warranty |
General | |
Width | 18 cm |
Depth | 7.6 cm |
Height | 19 cm |
Weight | 289 g |
Colour | Black |
Max Operating Distance | 30 m |
Audio Output | |
Bluetooth Profiles | Hands-Free Profile (HFP), Headset Profile (HSP), Advanced Audio Distribution Profile (A2DP), Audio/Video Remote Control Profile (AVRCP) |
Diaphragm | 40 mm |
Simultaneously Connectable Devices Qty | 2 |
Volume Limiting Function | Yes |
Microphone | |
Form Factor | Built-in |
Remote Control | |
Wireless Link | |
Transmission Range | 30 m |
Connections | |
Connector Type | Headphones (mini-phone stereo 3.5 mm 4-pole) |
Internet of Things (IoT) | |
Miscellaneous | |
Included Accessories | Carrying pouch, Bluetooth USB adapter, USB charge cable |
Cable Details | Headphones cable - detachable |
Power | |
Battery | Headphone battery rechargeable - Lithium Ion |
Capacity | 660 mAh |
Run Time (Up To) | 24 hour(s) |
Run Time Details | Continuous playback: up to 24 hours , Continuous talk: up to 20 hours |
Recharge Time | 150 min |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
