The Blackwire 5200 Series fits your busy workday. Easy to use, USB-C and 3.5 mm connectivity lets you work on a variety of devices. And it's so comfortable, you'll be able to wear it all day. The Blackwire 5200 Series-connect, work, seamlessly.
Product Description | Poly Blackwire 5210 - headset | Product Type | Headset - wired - USB, 3.5 mm jack | Recommended Use | Computer - communication | Headphones Form Factor | On-ear | Connectivity Technology | Wired | Sound Output Mode | Mono | Audio Specifications | Frequency Response 20 - 20000 Hz | Microphone | Boom | Controls | Mute, volume, answer/end | Software Certification | Certified for Microsoft Teams |
General | |
Series | 5200 Series |
Dimensions & Weight Details | 125.4 g |
Headband Material | Cushioned metal |
Earpad Material | Leatherette |
Features | Voice alerts |
Protection | Hearing protection |
Audio Output | |
Frequency Response | 20 - 20000 Hz |
In-Cord Volume Control | Yes |
Features | SoundGuard Technology |
Microphone | |
Type | Boom |
Frequency Response | 100 - 8000 Hz |
Remote Control | |
Connections | |
Connector Type | USB (4 PIN USB Type A) , Headphones (mini-phone stereo 3.5 mm) |
Miscellaneous | |
Included Accessories | Carrying case |
Cable Details | Headset cable |
